Could you please help ?
Hi guys,
when i run my landslide for high speed it dies(stall), especially when i quick pressing the speed truttle in the remote. could you please tell me what is the problem ?
regards,
SAMI
regards,
SAMI
MN
RE: Could you please help ?
Go back to these tuning setting and we can go from here for advice, if this doesn't help, we can move onto: air leaks, dirty air filter, clogged fuel filter and so on
thanx jigawatt
as I guesed the tuning is perfect now. the engine is startings somotthly and the car is running smooth but when i want to drive in high speed sometime it dies.
MN
IF they are small bubbles, more than likely they are just from vibration (normal operation).
If there are big ones, or a line of bubbles:
it can be one or two things...
fuel line has a few tiny holes in it
or the tank isn't sealed.
CT
if theres bubbles try running longer fuel line that seemed to help mine. and usually if the engine dies at high speeds you got it running to lean. richen it up a bit by turning the high speed needle counter clockwise. make sure theres smoke comming out of the exhaust when running or most likley your running to lean.
