Need help rebuilding my 2 speed transmission
IL
I was wondering if anyone can help me put together my 2 speed tranny for my tornado bb; i took it apart and i am not sure exactly how to put it together.
Possibly if someone could post some pics i would much appreciate it
CT
RE: Need help rebuilding my 2 speed transmission
Do you still have your manual that came with the car? It should have a diagram showing how it goes back together.
IL
The manual i have is from 2007 and it shows and it shows an assembled tranny thats about it i checked the redcat website and it is the same one the i have.
GA
Did you check Ali's video on Metacafe ondisassembly and reassembly of the 2 speed tranny? It might be a different vehicle but I bet it's close to the same.
http://www.metacafe.com/watch/249553...shifting_time/
IL
Thanks alot; one more question; do you need one or two set screws in the clutch where you secure to that shaft thing in the picture i am pointing at it with my screwdriver hopefully you can see it it is to right of the shift set screw.
IL
IL
either the allen wrench or the top of the grub screw is stripping; do you know of a good brand of rc tools that do not strip ?
CT
Redcat sells some that has removable allens and if you strip it you can just replace it. But all my tools are from automotive stores. Duralast makes some nice stuff as far as allen wrenches and screw drivers go.
MN
i bought a big yellow set, it has just about every alen wrench you need. just go to a autoparts store and pick up a set of metric allen wrenches
