New Earthquake 3.0 owner radio problems
GA
I am on the 3rd tank of break in procedure, about 25 feet away from the truck and it takes off, full throttle, so i'm holding back on the trigger for brakes and it does nothing to slow it down. it finally hits a house. 4th tank, same thing, takes off full speed until tangled in tall weeds. the whole time i'm on the brakes. They brakes work every other time. Is this radio interference. Ihave the AM #8 27MHz crystal. Do Ineed to just buy a 2.4 Ghz or is this faulty equipment?
Thanks.
Thanks.
RE: New Earthquake 3.0 owner radio problems
Make sure your reciever antenna wire is not wrapped around a servo wire, battery pack wire or the switch wires. if that does not cure the problem you are having make sure you have good quality reciever batterys and remote batterys. To prevent the run away problem it is a good idea to put a fail safe in your truck to keep it from running off. Here is a link to the fail safe [link]http://www.urchobby.com/proddetail.php?prod=03028[/link]
GA
I changed the crystals to a 26.9 mhz set i had from an old r/c jeep and it did the same thing. so i'm thinking either the batteries just in the receiver are dying already (the transmitter shows full charge) or, more likely, I have a bad receiver. What kind of warranty do you get on the elctronics?
NH
ORIGINAL: dublea
Also make sure the connector is secure.
GA
ORIGINAL: 71prostreet
Redcat covers the remote control for 30 Days.
According to www.redcatracing.com you have to go through the store you bought it from for problems/returns. Is this right?
no Redcats site says "All warranty claims must be handled through Redcat Racing and not your hobby dealer". If you want to return a redcat product you purchased from a dealer you must do so through the dealer. so you can just contact redcat about it and they will take care of you. For my customers I like to just take care of broken items myself it can be faster and reassures my customers of my commitment to great service.
I would find the source of the problem first. I have seen servo's cause radio glitches. Also you purchased a truck that is RTR not ready to buy a new 2.4 GHz radio set! As far as interference there are things that cause it but the best way to see if some one is hitting your freq is to move away from the common area you drive, go to a park or parking lot away from where you normaly drive and see if that corrects the problem (my guess is it will not). Yes a new 2.4 GHz is nice but you should not need it kinda seems like a waist of money that you can be spending on some thing better.
