Earthquake steering coming loose
GA
I have an Earthquake 3.0 that has maybe 8 tanks through it and the last two times I've run it the screw holding the servo arm to the steering saver set backs all the way out until it's no longer attached. Is this the sign of another problem or should I put some blue thread sealer on it? It's plastic to plastic though. Any advice would be appreciated.
RE: Earthquake steering coming loose
another little trick you can try iss take a lilttle bit of fuel tube and put in there with the screw gives it abtight fit and a bit more grip
