stripped grub screw
IL
stripped grub screw
Does anyone know how to remove a stripped 4MM (grub screw) set screw out of a drive cup that is attached to my 2 speed transmission ?
I dont think theres a screw removal kit small enough ?
RE: stripped grub screw
ORIGINAL: basketballfan60123
NH
ORIGINAL: RCToysNh
Old secret. Take a pc of paper and place over hole. insert wrench into screw through the paper. If you do it right the paper will act as shim on all sides around the wrench. You can go to any hardware store for a new screw.
