Volcano s30 brake upgrades
i have a volcano s30. i keep on going through brakes.the middle kepps on striping.i want to upgrade to metal brake pads. i need to know which ones will work for it
ON, CANADA
RE: Volcano s30 brake upgrades
??... by "middle stripping" do you mean the pads? If so, the brakes must be over-tightened, adjusted improperly, Or the disc may be damaged. I have had the same set of pads for two years. and i run it pretty hard.
yea the middle.my barkes are rally loose.it i loosen them more my brakes wont work.it takes a really long time for my truck to stop because if i tighten them to where their supposed to be they wear out in an hour
ON, CANADA
the screws holding the shoes and pads to the transmission should be tightened so there is minimal slop between them and the disc.(but causing no drag) Then all of your adjustments need to be made by the brake adjustment knob, and throttle linkage.
FL
ORIGINAL: a4d2a0m
the screws holding the shoes and pads to the transmission should be tightened so there is minimal slop between them and the disc.(but causing no drag) Then all of your adjustments need to be made by the brake adjustment knob, and throttle/brake linkage.
