Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Vortex EXP
Reply
Old 03-13-2010, 05:19 PM
onenut78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Redcat Racing Vortex EXP
hello all, i'm upgrading the wheels and tires on my Vortex and was wondering whats a good pinion gear set-up for this and where to get it from? also, i need good shocks. any suggestions? thanks
onenut78 is offline
Old 03-13-2010, 06:58 PM
AllAboutFunHobbies
AllAboutFunHobbies's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Vortex EXP
Uhm, what wheel size are you upgrading too, Wider, thicker, thinner? You need to gear your truck accordingly.
AllAboutFunHobbies is offline
Old 03-14-2010, 08:54 AM
4goodbuys2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what rims and tires did you choose
4goodbuys2 is offline
Old 03-15-2010, 07:36 PM
onenut78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bought the traxxas BF Goodrich Mud-Terrains with the chrome and red rims from the slash
onenut78 is offline
Old 03-15-2010, 08:38 PM
billymare
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice wheels and tires... Letus know how they work out..
billymare is offline
Old 05-17-2010, 08:36 AM
rccrazer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey my friend. if its the brushless set up on the pro try to keep the motor and esc under 200 degrees f. any hotter and magnets loose strength. this will over time cause the motor to fail. i fun mine around 150-175. if its too cold then its going to just going to wear esc out due to the strain the esc is getting pulled on. so just watch the temp.
rccrazer is offline
Old 05-17-2010, 09:26 AM
onenut78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well, the tires and rims look great on my vortex. they handle great also! i don't have the brushless system in it. i did change out the motor and esc to the traxxas titan 12t and the traxxas xl-5 esc.
onenut78 is offline
Old 05-17-2010, 10:06 AM
rccrazer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
then i would check your brushes often. and keep the heat a low as possible try putting some other pinions on and see if that helps the heat. heat in brushed motors can cause meltdowns. and if they go unchecked you can weld your motors stator to its rotor. also to much strain can wear out your brushes. sometimes going up in pinion size can help too. and with the higher speed from the 12t motor youmightneed that.
rccrazer is offline
Old 09-01-2010, 05:10 PM
rccrazer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
actually the redcat aluminium shocks are wondergul except that the bleed holes are huge!
i use them
rccrazer is offline
Contact Us Archive Advertising Cookie Policy
