Wheel Adapters
Wheel Adapters
My query this time is if it is possible to use the 17mm wheel adapter conversion kit for the Traxxas Slash 4x4 on the Redcat Earthquake 3.0?
My Feedback: (32)
IA
RE: Wheel Adapters
I believe that as long as you go from 17mm to 17mm you should be fine depending on the tire/rim. Certain tires are wider and taller than others which can cause the tire to rub on the inside of the front A-Arm when turning.
