Earthquake Engine change question
TX
I'm bidding on an Earthquake without an engine.
I have an AB Drag Mod Picco .28 in the garage not used.
Will this truck do ok with this engine?
If so is it a direct drop in?
and if so, that do I need as far as additional parts....? Like, pinion gear, flywheel, clutch, clutch bell etc...
Thanks in Advance guys!
_____________________________________________
my email address if you'd rather is..
[email protected]
or [email protected]
-Josh
[email protected]
-Josh
Moderator
RE: Earthquake Engine change question
I think so. I don't have the car nor engine. As long as it's nitro, it should fit. .28. parts- umm... I'm new to nitro, but researched alot. You's need an drive gear, slipper clutch, and whatever was in their before. forgot to add, a new engine mount. Hope this helps.
Josh- if it is an earthqauke 3.5 then that .28 will fit without any issues but you will need the engine mount and clutch assembly if it is not being included with the truck, If it happens to be a earthquake 3.0 then the biggest engine that will fit is a .18 and the 3.0 uses a different chassis and such.
