If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2003
    Ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How tight should the screw holding the clutch bell be?
    Hey all,
    I'm just wondering how tight the screw that holds the clutch bell on should be. If I tighten it all, it seems to bind up the clutch bell and keep it from spinning freely. If i don't tighten it looks like it will just fall out.
    Any help would be appreciated.
    Rob
  2. #2
    UrcHobby's Avatar
    Join Date
    Nov 2002
    Bellmore, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: How tight should the screw holding the clutch bell be?
    Hey Rob, You want to have that bolt tight and also make sure to use some locktite on it. If when you tighten it down it binds you need to first make sure you have the shims in the right place. If you are installing new components i.e.: new clutch bell or bearings, you might have to remove a shim.
    Urc Hobby Dealer LI New York
  3. #3
    Join Date
    Oct 2003
    Ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey thanks for the help.
    I am in fact replacing the original clutch bell with the newer steel one. I don't have a pic yet, but the set up looks like this: screw, lock washer, washer, 2 shims, bearing, bell, bearing, 2 shims. Something must not be right because if I tighten the screw, it really does bind up.
    Cheers,
    Rob
  4. #4
    UrcHobby's Avatar
    Join Date
    Nov 2002
    Bellmore, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Rob, No problem at all. Just remove 1 shim and see how it is then. That should do it.
  5. #5
    Join Date
    Oct 2003
    Ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, great! I think I've got it. I had to remove all the shims and just keep the washer and lock washer,but it fully tightens, and the bell spins freely. Thanks again.
    There also seemed to be an air leak around the seal of the gas tank lid. I fiddled with the screw last night and this morning it seems to have a better seal. And lastly, I need to find my glow plug starter charger. I haven't worked on this car since and the fall, and it must be lost in the basement somewhere. Ugh. And I think I've got 2 of the things!
    Rob
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
