Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
100 degree weather and nitro
Reply
Old 07-19-2010, 05:23 PM
rokit_armor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 100 degree weather and nitro
My truck is overheating pretty fast today, after 5 mins I have to rev the throttle to keep it alive.
Would this have anything to do with the nice 100+ temp here? It does normally run hot and start to vaporlock but thats after 3/4 tank has run through, not 5 mins in.
Should I just not run it when it's this hot, or do I need to run it more lean/rich?
On a side note, city dumped the hydrant by my house leaving a 4" deep puddle 10' long- truck goes right on top of it no problem at full speed! Although the tires come out with the friction of hockey pucks on ice....
rokit_armor is offline
Old 07-20-2010, 11:20 AM
Redcat-Derek
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 100 degree weather and nitro
Rokit,
You should be fine running in 100+ degree weather, when going from a colder to hotter temperature you will need to lean the needles to compensate for less density in the air. What probably happened was by going to a hotter temp and keeping the same tune the engine is now richer causing the idle to drop.
Derek
RedcatRacing
Redcat-Derek is offline
Old 07-20-2010, 07:24 PM
kelynsdad1023
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
also try using a cooler glow plug .
kelynsdad1023 is offline
Old 07-20-2010, 08:52 PM
qoisdhc oqina
My Feedback: (-1)
qoisdhc oqina's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its hotter out.Run it richer.Less heat.You lean it up, its gonna make the heating problem worse.You run it lean, it heats up faster and gets hotter.You run it richer and it runs cooler.Richen it a little.
qoisdhc oqina is offline
Old 07-21-2010, 12:51 PM
Redcat-Derek
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
qoisdhc ogina,
Common sense would  tell you that you would need to richen the needles to keep the engine cool, but you actually need to lean the needles when the temperature is hotter. Reason being is that the hotter air is thinner and less dense, thus meaning that in a cubic foot there will be more air in colder weather than the hotter weather. With less air you need less fuel.
Thank you,
Derek
RedcatRacing
Old 07-23-2010, 06:50 AM
catbob007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WHERE
catbob007 is offline
Contact Us Archive Advertising Cookie Policy
