Making an 8E rear wheel drive instead of all wheel
I was thinking about removing the drive shaft to the front to see if its faster and or stops wheeling...has any one done this yet...what do you thing???????
RE: Making an 8E rear wheel drive instead of all wheel
Well I think it would be faster, causeyour not straining the motor, your taking more work off the motor turning two big wheels instead of four big wheels...I dont know but it just make sense to me
SD
you could try removing the front drive shaft but your rear diff will be recieving twice the power that it is used to and will not last long, but the fun factor is hard to beat
My Feedback: (-1)
AE
ORIGINAL: sdnitro
Hod do you figure?Is the motor producing twice the power because its only rwd?No.The shaft is spinning the same speed, the wheels are spinning the same speed.How is that extra strain on the diff?
On my vendetta, i just took the front diff out. But it was broke and i dont have the money to get a ball diff, and it strips the gears every run, figured id leave it that way.Rear is a ball and has been fine.
dont know how the 8e is set up, but just remove the front diff.
ORIGINAL: 98cruiser
Have you tried it yet?????? I ask this becuase once you pull the front shft out it would notwant to move very well................the center diff needs both shafts to operate correctly and put to put the power down.
AZ
Hello,
Having a center differential, you will need to either keep it 4WD or lock the center diff and run RWD which I wouldn't recommend. If you just take the front drive shaft out the center diff let the front side spin like crazy but giving almost no power to the rear.
Derek
RedcatRacing
Derek
RedcatRacing
FL
I dont know about increasing the speed, but if ya want it to stop pulling wheelies, try tuning the diffs with different weight diff fluid.. I wish I had a link for ya, but try a search on here for "differential tuning" and you should find some decent info on what weight fluids to use, to solve your probs! Good luck!
ORIGINAL: Mickstix
Well or you could do what I did and do the 17mm swap and buggie wheels/tires and make it a Backdraft. No more wheelies and handles way better!!! But with the big wheels and tires it was cool because when you punched it was an animal!!!
SD
I just figured when you are using two difs the power is divided in half between two diffs. When you eliminate one diff all the power will be
transfered to one diff instead of two. I agree with redcat derek the transfer case will want to power the path of least resistance which would be
the front diff. I don't know a easy way to lock this but i am sure someone does. I have an earthquake 3.5 and i have a hard time keeping diffs in
that thing and it is set up stock.
ORIGINAL: formula87
FL
ORIGINAL: catbob007
If you did your diffs like in my diff thread You wouldent have to worry about diffs wearing out.
Can you post me a link to your diff thread please???
THanks
@sdnitro, Well it easy to lock the center diff, on my 8E I just opened it up and cleaned out as much diff fluid I could andfilled it withsome epoxy, changed the spure and pinion gear ratio and he is a fukin BEAST!!!! I wipped the Traxxass car like 5 times before running head first into a damn telephone pole..lmaolmao Well granted it was a nitro car so compared to electric off the line nitro sleeps with out a good reaction time, but he still couldn't catch me>>>well back to the drawing board, but yes Im going to remove my front shaft and since my center diffs are lock, it should give a better reaction time andupgrade to 1.5 17mm wheel extensions with the HPI chrome wheel with Phatline low profile tires.................Illl keep you guys posted........Kurt from www.URChobby.com told me and supplied me with the gearsI needed tochange.............Kurt is the Sh!!!!t....you
