wont accelerate/shockwave clutch ?
My Feedback: (9)
ok so i bought a shockwave used and i believe i got the engine tuned ok, when i got it the spur gear was striped out, so i replaced it and meshed it via the paper method.
so my question is, it doesnt seem to have any guts off the line in smaller stones/gravel it wont even spin the tires. is the clutch engaging to soon and boging it down or is it something else. the spur and clutch bell turn fairly easily by hand also, also i cleaned the clutch bell and it did have a descent amount of worn clutch dust. help what is it or am i missing?
NH
RE: wont accelerate/shockwave clutch ?
Several things could be wrong. If you pick up the vehicle does it spin all wheels as you rev it ?
Also it may have low compression, loose drive cups, bad clutch.
My Feedback: (9)
well when i lift and accelerate the only wheel that spins like it should is the right rear the others are much slower
what all do you want me to disassemble and post pics of?
NH
ORIGINAL: craigdennis15
My Feedback: (9)
ill check the brake disc, im begining to thinkits theclutch, i tore apart the diffs and asside from being a little dirty they were in almost perfect shape, actually i was quite surprised. the motorruns fairly well for what it is so idont think its low on compression.
im begining to think its the clutch engaging to soon and not allowing the motor to be up to its power before locking up or something.
im not sure exactly what to look for, as far as the meat left on the clutch, there is some material left from the spring up if that makes since but not a lot maybe a 1/16" maybe a little more.
thanks for all ideas and ill keep pluging away
ME
If it was the clutch then all the wheels wouldn't be spinning, not all but one. Missing dog bones? (I know, you checked that...)
My Feedback: (9)
i was more asking if the clutch could be engaging to soon via a weak spring.
i said that the righ rear spins faster than most it appears. all spin but right rear baloons out more like its spinning faster. all dogbones are there and i took apart the diffs and those look good.
maybe im asking to much from the car?
should it be able to spin the tires in stones on takeoff?
there are street tires on it so i dont expect it to on asphalt but it is pretty slow on takeoff compared to similar sized engined rcs ive had. im gonna try an hpi clutch bell (13t) and an alluminum clutch with traxxas spring. and try to tune engine better.
if any other ideas pls let me know.
also the street tires are close to same diameter but wider. maybe ill put stock on and try it
thanks all for the suggestions
My Feedback: (9)
ok i got a hpi 13t clutch bell and ordered the allum. redcat clutch and spring. is that spring that comes with allum clutch ok or is the traxxas spring guys use still stiffer. does it release or allow engagment at a higher rpm or is the one that come with the alluminum clutch the same as the stock one. in that case would i notice anything by goin with the stiffer traxxas one? thx guys
