Volcano EXP 1st run problem
I am new to rc and just got my Volcano EXP out of the box last night. First run today, I keep having to reset the ESC. It doesn't seem to matter what terrain or distance, and not getting stuck. It seems to happen when going from forward to reverse.
RE: Volcano EXP 1st run problem
so, it just stops moving?
does the steering still work? if the steering still works, them maybe the speed control is faulty? if so, fill out the warrenty form on the redcat site and they will send you a new one. is you loose both the driving and the steering, then it might be the radio. also, double check that the white battery plugs are nice and tight. those are not high-grade plugs IMO and have a tendancy to wiggle loose(just enough so power wont go through) |
The steering works. The light comes on the speed control, but no movement. I filled out warr. form, but was hoping could do something to use the truck this first weekend. Oh well!!!
ORIGINAL: raymez The steering works. The light comes on the speed control, but no movement. I filled out warr. form, but was hoping could do something to use the truck this first weekend. Oh well!!! if you were to upgrade, go for the traxxas XL-5 speed control. you can find them used for $25-35. they are higher quality, and would also allow you to upgrade to a faster motor later on. when you say that you re-set the ESC, do you mean that you turn it on/off? or do you mean that you re-program it? if you havent reprogramed it(re-calibrate) then i would try that. |
How do I re-calibrate it? I am very new to RC. I did not see anything in the manual to calibrate. Any help would be appreciated.
ORIGINAL: raymez How do I re-calibrate it? I am very new to RC. I did not see anything in the manual to calibrate. Any help would be appreciated. hold the reset button for 8 seconds, (reset button should be just below the LED) until the LED blinks slowly, then(while still holding the reset button) turn off the power switch. now turn it back on and see if the problem still exists. |
