please, steel pinion gear for aftershock 8e
hi guys, i sell redcat product in montreal region, and my drive is a aftershock 8e. you have a steel spur gear for us but now we need something stronger than a brass pignon gear to go with it!!! come on guys, from redcat racing !!! give us a steel pinion gear for those big truck!!! nobody seems to make some for us, would you..... please!!!!!
thaky you in advanced, and keep up the good work.... by the way, the same upgrade, spur and pignon(steel) should be avalable for the caldera sc-10 brushless... this is a big star!!!! keep up thew good work guys!!!! you really improve your product during those years.... please continu that way!!!!! sincerely luc brodeur jachobby, laval [email protected] 450-494-4894 quebec, canada |
RE: please, steel pinion gear for aftershock 8e
4 da aftrshok 8e, backdraft 8e & earthquake 8e, u can use hpi savage flux pinions.
mod1 pitch, 5mm shaft & it cums in a variety of tooth counts. unless u want redcat branded steel pinions. but da hpi savage flux 1s will work |
ORIGINAL: firemansorel hi guys, i sell redcat product in montreal region, and my drive is a aftershock 8e. you have a steel spur gear for us but now we need something stronger than a brass pignon gear to go with it!!! come on guys, from redcat racing !!! give us a steel pinion gear for those big truck!!! nobody seems to make some for us, would you..... please!!!!! thaky you in advanced, and keep up the good work.... by the way, the same upgrade, spur and pignon(steel) should be avalable for the caldera sc-10 brushless... this is a big star!!!! keep up thew good work guys!!!! you really improve your product during those years.... please continu that way!!!!! sincerely luc brodeur jachobby, laval [email protected] 450-494-4894 quebec, canada Robinson Racing makes a very nice mod 1 with a 5mm shaft hole. They make from 12 tooth all the way up to 26 tooth pinion. IMO the best on the market. |
thank you guys for your help. i think that i will go with the robinson gear. but it should be a good idee for redcatracing to make there's....
