Volcano EPX Pro Dogbone
Can anyone recommend a better dogbone for the volcano other than the redcat ones? I keep bending and or losing my front dogdones looking for something better.
I have a link to some on ebay, but it won't let me post links until I've had 10 post, if you'll message I'll give it to you. I've had good luck with them, I run them up front with normal dog bones in the rear. I broke one on a bad landing from a big jump
2 Attachment(s)
Stock Volcano dogbones tend to be a little short. They will tend to come out in a hard turn. I used to shim mine with an 'o' ring. The Volcano front end has a variety of problems.
How did you shim them? And you said “I used to shim mine” did you find a better way? Having same issue after I upgraded to aluminum arms.
Use a small oring inside the diff out drive and another inside the axle . Helps keep the dogbone central . You can also use cut down foam ear plugs . A slightly longer dogbone is really what is needed .
Done....thanks for the tip and new longer dog bones are on order.
