cluch spring
where is the cluch spring? it might have been broken someone told me and I wanted to check and see if it really is... sorry for my ignorance
I am restless waiting fr parts to arrive so I said "if I can't play it I'll tare it appart [&:] |
RE: cluch spring
If you look at the engine you wull see the two gears for the two speed trans in fron of the air cleaner. That is the clutch housing. There should be a clip or something holding that on. The spring will be in there. I can't give you more info my car or parts sheet is no with me.
RE: cluch spring
thanx i just found it and.... its broken
can i buy just the spring or do i need to buy the whole thing? |
RE: cluch spring
I'm not sure , I heard of people going to there local hobby shop and using on from another brand. If you did that you would need to take you clutch parts up there and match one up. Try this dealer , I've heard he has really good service
http://www.clermontmotorsports.com/ |
