Almost Absolutely Perfect!
Hey everybody,what's up.Last night I had my volcano
out and was fine tuning the carb for the weather change and It happened.I must have had every jet In that carb tuned perfect,because this truck ran like it's never ran before.It has always been a very fast truck,but last night it was a super truck,this truck was so fast that I couldn't help myself from smiling,it ROCKED off the line,through the mid range and was very impressive on the top end. I can't beleive the speed of a perfect tuned vehicle,if your truck is fast,but not a bullet,then you are not 100% in tune! Now here's the funny or not so funny part of this story.I'm flying around and I get a glitch from my remote,I don't worry I just keep on rippin.I'm mad about a tree that has been cut down right where I like to do my best donuts on soft dirt,so I'm running around that area,I hit the gas the truck flies away and I notice I can't stop it,no throttle control.The same tree I was mad about saved my truck from its ultimate death.The truck ran into the tree branchs at wide open speed and sat there and dug ruts into the gound 3 inches deep,amazingly no DAMAGE.I take it inside and notice that inside my control box my throttle servo connection has come out,that's why I had no throttle control,wild huh.If that tree had not been there my volcano is toast.I wanted to share this story so you guy's could check on things like this,so it doesn't ruin your truck.These trucks are amazing when their running right,so have fun and keep on ROCKIN THE REDCAT'S!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
RE: Almost Absolutely Perfect!
awesome story man, i agree 100% if you have your car tuned right and everything checked before running it, this cars are a blast to drive, specially against people who think only $500 cars are the fastest or dont break ever:eek:.
same here, I tuned my volcano and it is a beast! not that I have seen many others :P but it really IS impresive!
however, I cannot manage to keep it in idle for a long time... I think it has to do with the new glow plug I installed. it is medium to cold and from what I have read in an other thread, it really helps if the glow plug is hot... Do you guys agree? or is there something else that I can do? thx |
Good story man!!
This has inspired me to fine tune my car even though it runs good enough at the moment. It's fast as it is now, but I may as well see its full potential!! :D - bspate - |
ORIGINAL: DiTi ....I think it has to do with the new glow plug I installed. it is medium to cold and from what I have read in an other thread, it really helps if the glow plug is hot... Do you guys agree? or is there something else that I can do? thx - bspate - |
ORIGINAL: DiTi same here, I tuned my volcano and it is a beast! not that I have seen many others :P but it really IS impresive! however, I cannot manage to keep it in idle for a long time... I think it has to do with the new glow plug I installed. it is medium to cold and from what I have read in an other thread, it really helps if the glow plug is hot... Do you guys agree? or is there something else that I can do? thx |
thanx guys,
I think it was your post Jack that I read and I ordered the same plugs... .....meanwhile though I striped the main gear :( the first one that strips after a little more than half a gallon... I ordered those too just now... chubs put me back in the game bro!!! |
Do you have holes in chassis that u see gears / flywheel ? If so try to cover them (i cut some thin plastic and made 4 holes so it is held by tranny screws). Now i occasionally have to clear gears from small rocks (occasionally means once every burned fuel tank ;)). BUt i drive it a lot on sand and gravel. Also if u hear some knocking that wasnt there a while ago stop the car and look at all teeth in spur and clutch bell , small sh.. gets there and doesnt allow gears to "dig" into each other properly and thats why they stip
http://mieszkancy.ds.pg.gda.pl/~jimi...na_zebatka.jpg <- an example :) |
nitro engines are not made to idle long, dont tune to idle, tune to performance. I use 20% fuel with a cold plug and mine runs fine. There is a saying that there is no race or first place for how long your nitro idles.
Second, if you cover the gears on the bottom any rock you have in the chassis will be caught there and not be able to escape and grind up your gears, thats why ALL nitro cars have a cut out on the chassis below the gears, its meant to throw the debris out. |
hey ehroof, I was hoping you would jump into this conversation... my engine wont idle for longer than 30 seconts without the ignitor on and sometimes it will stall if I stop the car. it's random, an other time it stalled when I tried to go full throtle. but all this is random, it doesn't always happen... I belive the car is well tuned in so I kinda blamed the whole thing to something else... that is why I am asking. could it be something in the fuel line? in the filter? or do you think I need to reset the tuning and start over? I have some time to think and do my homework untill the dif. gear comes in...:)
how is the compression?? sounds like your running too lean, richen high and low end an 1/8th. Nitro engines dont idle for too long since they will load up on fuel and stall(flood). Do you need to raise your idle a little bit? Maybe your low end needle is set wrong. it should be set so that when you pinch the fuel line it should idle for a couple of seconds then raise a little and die. if it runs for a while then dies out your low end is rich, if idle raises quickly and dies your low end is too lean. hope this helps.
from what you are saying I am probably running rich on the LSN cause it runs more that 2secs befor it starts to rise and then stall... I'll try that tomorrow.
thanx man you are realy helpful it's a bummer that I have to whait for the gear and its a bigger bummer that it stripped on a friday [:@] p.s., I have already ordered a hot plug, I will see how that works too. what is the theory behind glow plugs? do they stay lit through the whole function of the engine? I thought they are lit only when you apply the ignitor and the fuel exploded due to high preasure. |
they only light when the ignitor is on them, the heat range of the plug has the do with the length of the plug, longer plug is hotter shorter is cooler. Hot plug will make engine run hotter. Always good to try to use different plugs. i like cooler plugs, and richer engines unless i am racing someone.
Don't the long plugs mess with your radio receiver?
[X(] |
ORIGINAL: ehroof nitro engines are not made to idle long, dont tune to idle, tune to performance. I use 20% fuel with a cold plug and mine runs fine. There is a saying that there is no race or first place for how long your nitro idles. Second, if you cover the gears on the bottom any rock you have in the chassis will be caught there and not be able to escape and grind up your gears, thats why ALL nitro cars have a cut out on the chassis below the gears, its meant to throw the debris out. |
This covering the gear hole has peeked my interest (especially since I just stripped the gear)...what are other peoples thoughts on this...to me it makes sense...it would probably make sense to fashion some sort of cover in teh front that would stop pebbles/gravel/whatever from making it way to the gear area...thoughts, experience???
chubs that was fast man!!! thanx a bunch
I only wish I was more careful when orderning [&:]:( I ordered the wrong parts how many mistakes needs one to do until one learns... in Greece they say: who has no brains to think, has legs to walk....[&o] |
No problem. That was the wife. She ran it while I was away. She did ok... I would use duck tape if anything. This way the small stuff that tries to get out will stick to it and not get tossed around in the gears. Then everyday rip it off and put new piece on.
1 Attachment(s)
What a day! Got about 1/2 a quart of this Traxxas %20 through earlier and I think I like it better than the Trinity Horsepower %20. The little Vx.18 seems to run cooler with the same amount of power and takes to tune easier. So heres my question for other Tornado XP owners who have a temp measuring device (I use a venom smart temp failsafe). What is your average "putting" temps and what is your average hard run temps? Mine seems to teder between 240-260F (and its high 70's/low 80's today,a nice warm day) just cruisin around and still shoots up to 270-290F if I get alot of high speed passes in (I run in a paved parking lot surrounded by dirt&gravel areas). She's got some gusto,takes off quick and raps out with force and spits plenty of blue smoke on the throttle while only spitting a slight amount of unburnt goo while idling. I pinch the fuel line about 2" from the carb and it takes 5-6 seconds to die and the RPM's only increase a minor amount before it dies so In my mind,I think I have a pretty decent tune on it... Wouldnt you say? It still runs a bit hotter (no way your keeping this thing under 250F unless its idling which sits right at 218-220F in the sun with the body on). Maybe it just likes to run a bit hotter I guess... Its fast! Hella fast! And when you run it out of go juice and let it cool down to... Oh say 140-150F it'll fire right back up with the glow ignitor on for only 5-6 seconds and wont stall out.
Does it sound like its tuned 'ok'? Should I try running a cooler plug (currently running Duratrax Carbon speed) to help lower temps? Any idea's or suggestions? This thing is &100 leak proof to,the engines been sealed,lines and filter replaced&checked,gas tank sealed and exhaust de-baffled+gasketed and no leaks in/on or around the manifold.... Sound ok? Advice?.... These things are just way to much fun! |
ORIGINAL: chubbysdad No problem. That was the wife. She ran it while I was away. She did ok... I would use duck tape if anything. This way the small stuff that tries to get out will stick to it and not get tossed around in the gears. Then everyday rip it off and put new piece on. |
Why dont you post a pic of your redneck fix for the a-arm. They might get a kick out of it :)
Haha wow the whole family is getting in on the action.
next there will be a chubbysmom and cubbysaunt:D
