Some part is missing to change 47 teeth transmission gear
I have broke some teeth on my 47 teeth gear. I have remove the transmission and take out the two gear. When i try to put the one way bearing into the new gear, the hole is bigger than the old one. Which part is missing? Do i have the right part? My parts is #06032.
thanks p.s. i have tornado BB |
RE: Some part is missing to change 47 teeth transmission gear
nobody?
Wish I could remember where I saw this problem in the forums but I know I saw it. Ask the guys who sent you the gear they should know :(
from what i understand, redcat changed the gear or their supplier did so you need a new one way from them, call or go on their support on their website and find out.
the traxxas oneway fits but is wider so you may need to do some trimmig,working on that same problem.. shaved some of the bearing & some of the gear ,the hole on the gear needs to be drilled out a little bit than trim some off the gears .
if some one knows a better way please let me know right now im running a single speed from a friends volcano not as fast but works |
the new bearing should be available from redcat racing as of the 22nd of march but you'll have to call cuz it's not in the online parts guide yet also i used a traxxas hub hex and drilled the hole to fit the one way bearing that came stock and it has worked pretty well with no other mods needed also i just ordered a whole new tranny from rufaster and it came with the new gear AND the new bearing
I CALLED REDCAT AND THEY SAID THE NEW BEARING WOULDNT BE AVAILABLE UNTIL THE FIRST WEEK OF APRIL. I DIDNT WANT TO WAIT THAT LONG TO RUN MY CAR SO I WENT TO THE HARDWARE STORE AND BOUGHT A 9/16 NYLON NUT FOR ABOUT 60 CENTS. THIS FITS IN THE NEW GEARS PERFECTLY. I HAD TO DRILL OUT THE CENTER A BIT TO FIT THE BEARING IN THE NUT ( I FORGOT WHAT SIZE DRILL I USED) AND FILE THE NUT DOWN A BIT BECAUSE IT WAS TO THICK. I PUT IT IN MY CAR AND HAVE RUN ABOUT 10 TANKS WITHOUT A PROBLEM. USE A DRILL PRESS IF YOU HAVE ONE SO THE HOLE IS NICE AND STRAIGHT.
