What Legnth Dog Bones On Tsunami (Not Center)
I went to order new dogbones for my tsunami, I ordered the only ones I could find under Tsunami and they turned out to be 55MM.. well when I got them they were WAY to small.. I checked other sites and all I see for the Tsunami is 55mm and center dogbone. So do we use the 70mm from other vehicles or what?. Thanks
RE: What Legnth Dog Bones On Tsunami (Not Center)
Sorry to bump. Need to order the correct one soon.. Thanks
which ones are you looking for? from dif to wheel?
correct
The Bonz you need are the 8029-A for front and 8029-B for the rear.................could be reversed[:o] its the 6006 for the front drive shaft and 2003 for the rear:D hope that helps. if you want to do something real trick and widen your Tsunami about a 1/2 inch get the 8064 stub axle (2 sets) and 8065 (1 set) its a lot of difference in handeling:D good luck M8
are those redcat numbers I cant find those part numbers anywhere on the redcat site?.. Thanks
are those redcat numbers I cant find those part numbers anywhere on the redcat site?.. Thanks oops sorry for the miss spelling there Clermont[&:] |
8029 & 8059 are the same size dogbones that go from the Diffs to the wheel.
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php?products_id=192]http://allaboutfunhobbies.com/store/catalog/product_info.php?products_id=192[/link] |
here they are http://www.clermontmotorsports.com/s...ft-83mm/Detail
so is there diffrence front to rear or are the both 83mm?
Front and rear are the same.
