wont be runnin for a while
well i new it was goin to happen but i didint get the failsafe in time:(. i hit a jump and pined the thotle to get my nose up and my reciver switch got nocked off[:@]. so there i am running as fast as i can accros the yard while it dose a could flips,smokes a tree and then tumbles into the gargen fence wide open[:'(]. i broke the gas tank, 3 A arms, broke the peace that the arms go into the chassis on the back, bent 2 shocks, bent my chasis and im almost 100% sure i blew up my motor. when i try to turn ther flywheel it just makes a clicking sound so i gess i snaped a con rod and wrecked a sleave. man this teaches me to put a return spring on. i gess its going to be a month or two before i can run again b/c i cant afford a new motor[:o].[:@]. anyone out there wanna give me a good deal on a motor??? [8D]
RE: wont be runnin for a while
ORIGINAL: jumpanddrop well i new it was goin to happen but i didint get the failsafe in time:(. i hit a jump and pined the thotle to get my nose up and my reciver switch got nocked off[:@]. so there i am running as fast as i can accros the yard while it dose a could flips,smokes a tree and then tumbles into the gargen fence wide open[:'(]. i broke the gas tank, 3 A arms, broke the peace that the arms go into the chassis on the back, bent 2 shocks, bent my chasis and im almost 100% sure i blew up my motor. when i try to turn ther flywheel it just makes a clicking sound so i gess i snaped a con rod and wrecked a sleave. man this teaches me to put a return spring on. i gess its going to be a month or two before i can run again.[:@]. anyone out there wanna give me a good deal on a motor??? [8D] make a list of what parts you broke! and open up the engine i want to see what happened (and take pics of cource) and take pics of your whole ride! dude that SUCKS [&o] and that makes me want to get a throtal return spring! |
redcat engine replacement programm. lol
yes i would take a pic if i had a camera right now, lol mom is away with it[:@]
ORIGINAL: ldgasp redcat engine replacement programm. lol if you have a 1/10 get a 21 for Poops and giggels! |
i wish i could use the program but its not a redcat engine[:@]. gess ill have to start savin up for a new motor[:o]. i shouldent have gotton rid of the vx.18
ya i gess ill try and take the engine apart. kinda nervos doing that but i gess i cant wreck anyting:). anything i should watch out for with these little engines??? hope fully its just a con rod,pison and sleave so i dont have to drop 120 bux on a new motor[:@]
the only thing is, when you are takeing it apart take out the glow plug first then remove the head then the sleeve then the back plate then the conecting rod then the clutch and fly wheel then remove the crank. check it all for scratches. and if the conecting rod is gone might as while buy a new engine... what engine do you have?
Nothing to it... Take the backplate and head off, if your conrod isn't in pieces use the ziptie in the port trick to help pop the sleeve off. Conrod/piston comes off the crank just about TDC (with some gentle coaxing).
There's my Readers Digest Abridged Version... ;) |
ORIGINAL: retard1322 the only thing is, when you are takeing it apart take out the glow plug first then remove the head then the sleeve then the back plate then the conecting rod then the clutch and fly wheel then remove the crank. check it all for scratches. and if the conecting rod is gone might as while buy a new engine... what engine do you have? |
OOH Crap that sucks a hpi G3.0! that is a good engine! ya definitaly get a OS or get a SH
and can i have your old engine! see if i can fix it? lol Canada to Canada... well BC to BC Cheep shiping! |
ORIGINAL: retard1322 OOH Crap that sucks a hpi G3.0! that is a good engine! ya definitaly get a OS or get a SH and can i have your old engine! see if i can fix it? lol Canada to Canada... well BC to BC Cheep shiping! |
ORIGINAL: jumpanddrop ORIGINAL: retard1322 OOH Crap that sucks a hpi G3.0! that is a good engine! ya definitaly get a OS or get a SH and can i have your old engine! see if i can fix it? lol Canada to Canada... well BC to BC Cheep shiping! do you have a redcat engine If you got an upgraded motor through redcat it will only cost you half the cost of the motor Redcat Racing has one of the best engine replacement programs in the industry. For as long as you own your vehicle, Redcat will replace your engine no matter what happens to it. Burn it up, wear it out or beat it with a sledge hammer, Redcat will replace it for same or upgraded motor for only 1/2 of the retail price of the replacement motor you want to buy. |
ORIGINAL: jumpanddrop ORIGINAL: retard1322 OOH Crap that sucks a hpi G3.0! that is a good engine! ya definitaly get a OS or get a SH and can i have your old engine! see if i can fix it? lol Canada to Canada... well BC to BC Cheep shiping! |
ORIGINAL: retard1322 ORIGINAL: jumpanddrop ORIGINAL: retard1322 OOH Crap that sucks a hpi G3.0! that is a good engine! ya definitaly get a OS or get a SH and can i have your old engine! see if i can fix it? lol Canada to Canada... well BC to BC Cheep shiping! |
ORIGINAL: jumpanddrop lol ya ill give it a try. i just order all my parts and it just over 40 bux.[:@] i hate crashes. im going to order a retrun spring also. now i just have to find a good price on a engine. hopefully i can win a half decent one on ebay for 60 bux. maybe ill try that sniping thing:) |
ORIGINAL: retard1322 ORIGINAL: jumpanddrop lol ya ill give it a try. i just order all my parts and it just over 40 bux.[:@] i hate crashes. im going to order a retrun spring also. now i just have to find a good price on a engine. hopefully i can win a half decent one on ebay for 60 bux. maybe ill try that sniping thing:) |
Ya the only thing is take your rc with you and choose a spring that will pull the servo back then the reciver is off but not to mutch that the serco boggs and is rilly slow... so get a light spring but one that will pull it back
and glad i could help! |
ORIGINAL: retard1322 Ya the only thing is take your rc with you and choose a spring that will pull the servo back then the reciver is off but not to mutch that the serco boggs and is rilly slow... so get a light spring but one that will pull it back and glad i could help! |
ya the throtal return springs are more reliable than fail safes... if your falesafe has a batterie (witch i doubt) it will be ok, but if the power is cut to the fail safe you are screwed! but throtal return springs are a wonder i am going to get one tomoro when i go to my bilders suply
