help with repair on my volcano
figured i'd give this a shot, i'm trying to change the axle joint on my r/f wheel, its the end that attachs to the gear box. The front dog bone goes inside this piece on the inside(the outside dogbone attached to wheel axle). Redcat part # 02051 is the gear box, i have an extra 02033 and i believe this is the right replacement part (the dogbone doesnt obviously stay in since only one end is attached). I cant seem to unscrew this broken axle joint (every time i do the wheels move). And i dont believe the gear box opens up, it appears to b one solid piece. Please help.......<div style="overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none; border: medium none;">
the blow up view doesnt seem to help</div> |
RE: help with repair on my volcano
you will have to remove the housing#02051,take the screws out,split the housing,take the differential out,remove 4 screws and take it apart then you get to what youre looking.if it popped out,the e-clip probably just needs replacing.
ok so i got to the gear or is it called the differential. how do i remove one of the wheel axles , do i unscrew it (i've tried to), pull it out? or does the whole differential have 2 b replace?
thanks |
take the 4 small screws out of the ring,the big gear on the differential,it will separate.
