Gnat
CA
Gnat
Almost finished my modified gnat. its powered by a os .10fp. it uses wood instead of metal for the fuse and micro radio gear instead of standard. hopefully it will be able to get off the ground!!!!
My Feedback: (20)
GA
RE: Gnat
Like the landing gear! I was thinking about getting rid of my Gnat and building one of the Spa3dt's or something similar because it's bigger with LG. I don't like hand launching. Your build is looking good!
CA
RE: Gnat
its a straight line deal. since the plane had no rudder to begin with so i didnt want to fiddle with it. besides i take off of an actual T-45 runway so i have plenty of room
CA
RE: Gnat
sorry about no post lately. been trying to tune the engine. i cannot get any smoke to come out no matter how rich and when i turn the plane nose up the engine dies
My Feedback: (20)
GA
RE: Gnat
May be just a long shot, but could it possibly be the orientation of your fuel and vent lines coming out of your tank? Don't know what the piping looks like inside, but usually, I see vent lines on top curved towards the top of the tank. Supply lines are in the center, or lower than the vent line with the line running into the tank...... Maybe there's a kink or something is goob'd up inside the tank. Just a thought 'cause I SURE ain't an engine guru! :-) That just caught my eye in your pics.
My Feedback: (20)
GA
RE: Gnat
Unless the orientation is correct and the fuel and vent lines are reversed on your engine. Been there, done that too! LOL But usually when I do that, the engine only runs for short bursts so I've got to where I figure that one out pretty quick. [:@]
RE: Gnat
Hi planeboy95
I'm going out on a limb on this one. I hate it when a new RC flier has a bad experience and as a result drops out of this wonderful hobby. I have been waiting for someone with Gant experience to advice you on this plane because I have never flown one. I did have a SPAD3DT and I believe there is some similarity between these two planes. None have come forward so I will stumble into it. I believe the Gant is not a plane to learn to fly RC with. Sure, it can be done, but it is far from being a trainer plane. I suggest you get someone to help you learn to fly.
