S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Ultra Spad Stik 4 mil wing?
Reply
Old 12-15-2010, 07:45 PM
bbrown2828
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ultra Spad Stik 4 mil wing?
Where can I get the plans for one of these I would like to build one around a dle 30 or a dle 55
bbrown2828 is offline
Old 12-15-2010, 07:52 PM
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This should get you to the plans:
http://search.rcuniverse.com/search....archwhere=both
Sincerely, Richard
spaceworm is online now
Old 12-15-2010, 08:00 PM
PatrickCurry
PatrickCurry's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or try here:  http://www.spadtothebone.com/SPAD/ultraspadstick/
PatrickCurry is offline
Old 12-16-2010, 03:08 AM
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A removable fuselage cover.
I'm sure I'll need to add some weight in the back.
joeskeeter is offline
Old 12-18-2010, 04:22 AM
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guess I'll put screws in the motor mount area to fuselage.
$8.00 foam safe ca woes.
Old 12-18-2010, 04:27 AM
  #31
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got half a wing glued.
Clamped channel iron onto the tablesaw to cut the 1 1/4 by !/4 to get
the spars cut finally
Thanks Carl for the motor. Funny story with the motor. It went from GA to NJ and then
back to GA.
ID:	1535561   Click image for larger version
ID:	1535562   Click image for larger version
ID:	1535563   Click image for larger version
Old 12-19-2010, 10:28 AM
  #32
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Made a measuring error found it.
Bottom wing panel I went too long on. Don't know how that happened, because it was a big measuring goof.
When I tried a test fold of the upper the ca again tore apart even
after scoring well on the upper wing panel.
Have been sanding and cleaning the surfaces with the degreaser and alowing degreaser to dry.
Fuselage fixed with screws.
All wing panels glued with goop this time.
Old 12-19-2010, 02:28 PM
  #33
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Goop or contact cement should work, but there is a process called plasma treatment that changes the surface tension of the surface molecules to allow effective bonding . Check with the SPAD website for this, although I don't know if anyone does it anymore. It involves passing the flame of a torch over the surface, but not to melt it, just to ionize it. The manufacturers of the plastic do it so that paint and ink and adhesives will stick to the polypropylene, but the treatment is uneffective after a while. The manufacturers use a plasma field to accomplish the surface change. Good luck
Sincere best wishes for a Happy Holiday Season and Merry Christmas to one and all.
Richard
Old 12-20-2010, 03:01 PM
  #34
PatrickCurry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Joel, how fresh is your CA?  Some folks report that older CA doesn't hold as well where fresh sticks like crazy.  You might try a fresh bottle and see what you get.
Old 12-20-2010, 03:51 PM
  #35
MrGreenSpeed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Woodpecker the area to glue and mix up poly glue with a drop or 2 of water, apply the glue & clamp.
Wipe up any over flowing foam.
It takes 3 or 4 hrs to setup enough to work on the next piece and 24hrs to cure completely so it's not as fast as CA, but it works every time.
Jeff
MrGreenSpeed is offline
Old 12-21-2010, 06:16 PM
  #36
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Went ahead and did goop and letting it sit for the 72 hours.
Started some fitting inside to figure where to put servos.
Made some tentative pieces to fit inside and just realized I forgot to plan a spot for a gas tank, so
one more thing to figure out.
Can the tank be placed towards the rear of the fuselage just back from the trailing edge of the wing?
I have to rearrange some screws to put it just back of the motor, if that would be better.
Got some leftover rc heli tanks, I put gas on the rubber grommets and they haven't melted or seemed to
have reacted to the gas so are they safe to use?
If anybody has some 4" wheels and a tail wheel they can sell please let me know.
Old 12-25-2010, 11:12 AM
  #37
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Progress pics and need some help advice on what to use for pushrods.
I got stainless steel welding rods and figured I 'd install some servos and
horn to see if they would break when I put a load on the elevator.
PUSHROD BENDING AFTER I THOUGHT I FOUND A NEAT PLACE TO INSTALL THE SERVOS.
HELP IF ANYONE IS STILL FOLLOWING THIS !!!!!!!!!!!!!!
ID:	1538146   Click image for larger version
ID:	1538147   Click image for larger version
ID:	1538148   Click image for larger version
Old 12-25-2010, 03:58 PM
  #38
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I am still here and enjoying your build.
You will need to add guides in several places to support the pushrods and to keep them from bending. The SS welding rod I am sure is strong enough, but may not be hard enough not to bend even if supported. Another approach is to use dowel pushrods, or better, carbon fiber or fiberglass arrow shafts. I pay less than $1.50 for a carbon fiber arrow at Walmart, and they do not bend. Another approach is to use pull-pull, with control horns on both sides of the surface and braided wire or Kevlar cord to move the surface.
Looking real good, you are getting real close. I really like some of your ideas and innovations. That is what I really like about our hobby.
Sincerely, Richard
Old 12-26-2010, 11:04 AM
  #39
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Walmart sold out of the carbon fiber arrows. But on the bright side I scavenged some decent sheet
metal scraps to use.
Makes me think how tough it must have been for the Wright brothers.
Something to think abou,t their plane I think 1904 to what we have now in the space shuttle.
Old 12-27-2010, 07:46 PM
  #40
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Progress milestone fuselage braces and hor elev braces, and all scratch build day.
Guess what the wire clamps are and win a prize !
Scratchbuild days are funnest of all as long as the blood loss isn't too high !
ID:	1538864   Click image for larger version
ID:	1538865   Click image for larger version
Old 12-29-2010, 04:19 AM
  #41
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the dihedral main spar assembly hers a way to clamp and screw the
middle spar reinforcer if you didn't get it exactly right in cutting
the angled portion.
ID:	1539319   Click image for larger version
Old 12-29-2010, 04:27 AM
  #42
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a work around if you want a collet and can't find one.
All 3 hardware stores here don't have collets that are rc sized.
if you want one for a certain size then if you have access to a drill press you can make it.
Take a piece of rod 1/4 inch would be easiest, cut and then center as best you can in a drill press.
Drill small hole for pilot. Then you can do the bigger hole .
I tried a quik one yesterday and didn't get it quite centered.
Old 12-29-2010, 04:55 AM
  #43
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Physics question.
What's a simple brace you can make for the landing gear on the 45 degree spots preferably
non welded since I would have to go 100 miles to use a tig machine.
I did visit a local FAA certed shop yesterday and they would charge $200-$300 to weld the gussets on since it would need to
have FAA certification due to them being FAA certified.
So that's out as an option.
Old 12-29-2010, 05:23 AM
  #44
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have some carbon fiber 1/8 rod coming, nobody close by has carbon fiber rod. Also none of the stores
here sell hollow tubing that is suitable for rc, smallest size rods I found are electrical conduit.
And since the cheapest carbon fiber arrow tubes are $7.95 I am still thinking about how to reinforce the 1/16 welding rod.
The rod seems to bend in a particular spot on both sides about the same distance. It would seem to me that you could solder
a small brace in 2 areas so that the flexing would stop.
I would like to figure this out because if anybody else is out in the middle of nowhere like me and just has
to have a pushrod now, then it would be nice to have a workaround until you could order some carbon fiber.
the desired pushrod brace would be attached to the pushrod only and not braced on the fuselage. The pushrod
would be attached to the servo and control horn only.
If somebody has the physics know how to suggest an idea you could give me a hint rather than tell me how to do it
because I like to figure it out.
Old 12-31-2010, 05:54 AM
  #45
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Captains log: Stardate 2010.
My phone fell into a cup of coffee.
Got the motor on to see how it looks.
Both spars on bottom of wing Progress is good.
Anybody got a design idea, here's a pic.
Old 12-31-2010, 06:03 AM
  #46
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And another funny story.
Walk into a local FAA shop that makes aircraft components.
Ask to see somebody that can suggest where to reinforce my latest landing gear idea.
I said" I have an aeronautical question".
The fellow replied, "can you spell aeronautical ?".
I said, shore can, "a-e-r-o-k-n-o-t-i-k-a-l ".
Long story short, I got to see their inhouse guy and he spent alot
of time looking at the design and making some good suggestions.
So, the story had a happy ending, you'all.
Old 01-01-2011, 05:09 AM
  #47
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's an idea to assemble and bend the 3mm aluminum bar into
a nice landing gear.
You're thinking, why would I build somthing like this to bend 3 mil aluminum?
Because it's hard to bend and I don't have a vise set up yet, and you set up the smaller blocks to
do some of the bending, you use the little blocks to bend with, you still have to do
some metall beating but the jig keeps the shape and angles in the right places.
(Got 2 quotes to make 4 bends.
$300 at one place and $75 -$100 an hour at the second place.)
Ok, get some 2x4 and start cutiing.
Assemble a 45 degree inner bend portion into 2 legs 45
degrees and the top I went with 3 1/2 inches portion
that goes to fuselage.
Legs are 12 1\2 inches and wheels 3 1\2 which is an
estimate since the wheels aren't here to see what Ineed there.
Cut up lots of 5 inch blocks to clamp with.
Pictures show the unit. clamp first bend starting left.
ID:	1540617   Click image for larger version
ID:	1540618   Click image for larger version
ID:	1540619   Click image for larger version
ID:	1540620   Click image for larger version
Old 01-03-2011, 07:22 PM
  #48
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm still so pissed at all the work to bend the landing gear that I
got a touch of love hate and irritated that the coro can be tough to work with and on and on.
Got sick of looking at the inside of the fuselage with the crooked yardstick that I put in to align the tail and
get the horizontal surface to track straight or at least look straight.
Used all the high tech tools at my disposal as you can see.
I swear, if I win the lottery after helping needy people, I'll get a decent tool or two.
So here's what my feeble brain came up with to cover the inside and also block what will be the gas tank area.
If i get some gas leakage I was thinking to cover the radio area from the gas area. Hmm, what to use. Got some coro made a gasket by cutting a flute trimmed one
longitudinal flute and bent the other back and I got a neat gasket effect.
ID:	1542029   Click image for larger version
ID:	1542030   Click image for larger version
ID:	1542031   Click image for larger version
Old 01-03-2011, 07:28 PM
  #49
joeskeeter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got the hang of flashing the coro and once you get it it is unbelievable.
The ca sticks like i don't know what. If you hold the coro up and let some light
shine on it at an angle and torch it you can see the change in the plastic.
I tried alot of different techniques to be able to see the change and nothing worked until I
could get the right angle.
It's worth burning up some pieces to figure it out.
I still sand and degrease and once it's flashed the stuff stays stuck !!
Old 01-04-2011, 05:26 AM
  #50
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to hear the heat treatment works for you. Helps keep things stuck together. I will check and see if walmart has any $2.00 carbon fibre arrows left. If they do I could send you some. Let me know.
Happy New year.
Sincerely, Richard
Reply
Display Modes
