If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 9 of 10 FirstFirst ... 78910 LastLast
Results 201 to 225 of 235
  1. #201
    Join Date
    Aug 2002
    Cisne, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Ultra Spad Stik 4 mil wing?
    Clean and others
    What are the dimensions of the PVC you are using on your USS ? When I built my first one, I used 3 1/2" PVC fence post cover obtained from Lowe's. Since then I have not been able to find this dimension at any "box store". Has been replaced with 4".
    I like to build my fuses out of PVC entirely with lightening holes made. Makes for a stronger, more rigid fuse.
    Not sure what the weight addition would be with 4" over 3 1/2". Probably minimal if made with the lightening holes.
    Cary
  2. #202
    Clean's Avatar
    Join Date
    Apr 2002
    Parkville, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That's what I'm using, it's all I could find. The inside is made to fit over a 4x4 (3.5x3.5) so I figured that's what they meant. Anyways, thats what I'm using.
    Intentional landings WITH a PBF are not
    the intentional design OF the PBF
  3. #203
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I drilled big holes in mine.
    In looking at my build notes I have 1030 grams or 2 pounds 4.3 ounces as the fuselage weight.
    Can't remember what was in the fuselage at that point, and my notes are sparse, but I believe this
    was the weight of the fuselage and the former only which would have had the holes drilled.
    I used a 3" or 76 mm sized hole saw and when I take the gear off I'll see how many
    holes I drilled. I didn't drill out too close to the motor mount, i think I went back 2" or more.
    Only drilled on the vertical sides, both sides.
    i left the whole former intact, where Kraut cuts a angle out of his I chose not to and I'm glad I didn't cut the angle
    out of the top because that area I have glued a wood block to and it has made the wing have alot to hold onto.
    I just weighed the other 11" x 4" piece pvc former I have cut for the next build.
    This is the weight with no holes drilled in it, 537 grams or 1 lb 2.9 ounces.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1600813   Click image for larger version.
ID:	1600814   Click image for larger version.
  4. #204
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here's the gear picture twisted a little.
    I've got another piece of the same aluminum
    that I could use for the time being.
    Any physics guys here that could calculate an attchment point for
    a brace.
    I've got lots of places to attach a brace so where to attach.
    or altenately maybe some welded gussets on the gear, how about some ideas?
  5. #205
    PatrickCurry's Avatar
    Join Date
    Jun 2009
    LaGrange, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Joel, seeing that photo gave me an idea that may have been used before, I don't know.  You know how people zip-tie bamboo skewers along the length of a pushrod to keep them flexing.....  I wonder if you got some light wood, maybe shoe molding or even pieces of yardstick and thread-wrapped it and CA'd it to your gear.... I wonder if that would keep it from bending.  I mean a really doinked landing might snap the wood, but with the two laminated together it would be pretty strong.  Or maybe even use a carbon fiber arrow shaft and just put it down the length of the gear.... spray paint over it and no one would know the difference.  What do you think of that Clean, do you think that would strengthen the gear sufficiently without much of a weight penalty?  Or would that make it *too* rigid and prone to constant damage?
    Glow Head Brotherhood #105
    Sig Kadet Brotherhood #201
  6. #206
    Join Date
    Jun 2009
    LaGrange, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh yeah, I'm afraid if you go with bracing attached into the fuse Joel and you doink that, you could possibly do some pretty serious damage to your fuse.  I am ignorant about these large birds though, I have to admit, so I'm not sure what would work or not.  [8D]
  7. #207
    Join Date
    Mar 2009
    Guilford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JoelStolarski
    a brace.
    I would go for a wider piece of aluminum for the gear if you can't get higher strength material. 6061 -T6 or 2024 alloy would be better. I get mine at a local salvage yard, but some is marked for type and some not. Another thought is to laminate two thickness of the aluminum you have. Another thought is to lay up a fibreglass gear or cover your aluminum gear with glass cloth and epoxy resin.
    You could run a piece of music wire from the lower ends of the gear in an angle up towards the center and then put a fairly heavy spring from that top vee point to the center of the fuse. That would give some shock absorbing and added strength to the gear.
    Another SPADDER used a half of a bicycle rim to make a landing gear. A half of a 20 inch rim would give you 10 inch plus one half of the tire diameter clearance to the ground for prop clearance. The rim is designed for light weight with strngth and shouild work good. An aluminum rim would be lighter than steel.
    I attach my gear to my fuse with nylon bolts into captive nuts. That way, I shear the nylon bolts on a hard landing instead of bending the gear or ripping out the fuse.
    Good luck.
    Sincerely, Richard
  8. #208
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The laminate idea or carbon brace sounds good guys.
    I really like to buy the darn landing gear but I am too stubborn or too dumb and like to figure
    something out like this, and I have the spare piece so I am still in a mode to try innovations and
    stimulate my brain to think harder than it is used to thinking,
    if anybody can understand that.
    I am missing flying my beast so I better get her fixed.
    Had my first engine die in-flight on the nexstar. lIKE FOR A SECOND I STOOD THERE MOUTH OPEN AND LIKE YOUR BRAIN JUST
    DON'T WANT TO RESPOND, FUNNY STUFF !!!!!!
    Good thing she glides for what seemd like an eternity.
    Almost knocked the tripod over that was holding a new
    camera that I was trying to see if I liked since it's been taking a while to find a point and shoot that takes good pictures.
    I didn't freak out like usual so that was a good thing, but it decided to stall at takeoff.
    So I have been doing takeoffs straight up and gaining altitude before I do turns but she wasn't high up really.
    But !!!!!!!!!!!! SHE WAS OVER THE PLOWED AREA WHERE THE STIK HIT DAMN NEAR SAME SPOT, IT'S LIKE A BERMUDA TRIANGLE THAT SPOT !!!!!!!!!!!!!!!1
    Phew, I got her turned around to land and then the kicker is she starts gliding and gliding and it's like i can't get the son of a gun down and shes gliding
    towards the lake.
    Got her down right at the edge of the runway and that was about 50 feet away from the water.
  9. #209
    Clean's Avatar
    Join Date
    Apr 2002
    Parkville, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Amazing how a little headwind can shorten a glide path/takeoff path.
    It does just the opposite when you're going downwind!
  10. #210
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tried out a camera panaorama
  11. #211
    Join Date
    Mar 2009
    Guilford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kool. I just found that my new cellphone has this feature. Have to try it out!
    Sincerely, Richard
  12. #212
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks.
    got the gear off the spad so I'm gonna try and hunt a welder down and use some of the old gear to
    reinforce the new gear.
    Got to mow the field again.
  13. #213
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Knocked out a gear and put it on.
    I sat and tried to figure out some kind of brace and then tried
    to get one of the old welders fired up, but
    the welder wasn't cooperating and then the
    batteries went out on my welding hood, so I had enough.
    Drilled holes screwed it together went with a small piece of aluminum brace.
    I got to thinking about a wood gear and making it oval cross section, but can't afford to buy all the stuff right now, so back to
    scavenging or using what's on hand.
ID:	1603913   Click image for larger version.
ID:	1603914   Click image for larger version.
  14. #214
    Join Date
    Jun 2009
    LaGrange, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks real nice Joel!  That should hold up to all but an actual CRASH landing. :-)  Looks like you've got some toe-out in your wheels though, you might want to check that and angle them inward a bit.  Fly that bad boy!
  15. #215
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Patrick I think your right on the toe out.
    I put the wheels on and might have to sdjust.
    I reread some posts and I think it woulsd be good to
    start on a gear with the principle you mentioned on a stable rod down the length of the gear strut.
    I wqant to order some of the carbon fiber sheet, checked prices and the stuff is not cheap.
    And I have to get the resin and hardener so cheapest I found was on ebay a good sized sheet and the resin and hardenber fo around $30.
    Would like to not waste it so I think I'll get some ideas and a design first before just going ahead like usual where I
    just do stuff haphazard and hope it turns out.
    Been through alot of wood and metal doing things that way.
    Been fixing vs flying did alot of patches last night on the Nexstar, learning how to work the ultracote.
    Used a regular iron at wool setting and that stuff is great.
    It sticks real good, you can shrink it stretch it curve it.
    fixed the sport stik,had alot of wood to repair and then had to patch it.
    Using non acetone nail remover to clean the old fuel and wood and I'm getting good adhesion, had the stuff
    on hand, so tried it. Would have preferred to get some of the special cleanr for balsa but budget is a little tight.
    I bought a Arrow trainer that should be here monday, probably should not have spent the money but it took a long time to find
    one and this one is never flown still in the box. It's a few years old so hoping the wood it's still ok.
    Got to learn how to slow the planes down at landing, otherwise I'm gonna have more fixing than flying days.
  16. #216
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bad crash with the "Beast".
  17. #217
    Join Date
    Jun 2009
    LaGrange, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Uh oh.... give us the scoop.  You weren't trying to fly in too much wind were you?
  18. #218
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There was a little wind, but real light.
    She's heavy and seemed like the motor just wasn't pulling good.
    Split fuselage and motor got full of dirt.
    took the motoraprt a little to clean and the carb off and I think i've got it clean.
    There is a little play on the connecting rod to the piston don't know if it's normal.
    got to film it and then somebody can look at the video to diagnose.
    She's fixable and I'm going to have to see if i can remove some weight somehow.
    Wings ok servos all that ok.
    I flew the nexstar after the crash and finally got a couple of super smooth landings done so that's getting better.
    II went to fly saturday and I guess I been brooding over the spad, and forgot to bring my radio.
    So I shot a bunch of pictures to do a panorama of the field,
    I tried loading the raw panorama into realflight and the field isn't showing up.
    Posted a help thread in the rc simulator section here on rcuniverse and I'm stumped.
    I've got enough photos to get the 360 x180 but can't seem to get the stiching programs to produce the
    panorama because they get bogged down when I use the pictures that have alot of sky in them.
    I've got about 600 shots if anyone want's I can email the folder .
  19. #219
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  20. #220
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I took a little time to figure a repair on the fuselage.
    I was in Las Vegas last week to take a turbine class so that
    was the high point of the last few weeks.
  21. #221
    Clean's Avatar
    Join Date
    Apr 2002
    Parkville, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gotta start bolting the big pieces together on mine.
  22. #222
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That looks nice.
    Red looks nice, I just can't see the orientation too well with the red.
    my brown wing is even worse.
  23. #223
    Clean's Avatar
    Join Date
    Apr 2002
    Parkville, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I see red and white or red and Yellow fairly well. I have a buddy that only can see Orange and Black. Every one is different. I actually prefer the Red and Yellow, my two favorite colors, and see them better BUT they didn't have any yellow the day I bought the coro and all of my sticks except one were Red and Whitee.
  24. #224
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So did some fuselage repair and some screws and glue and although the coro is split she's tight
    at the split.
    Gonna straighten the gear.
    I'll put a 5hp lawnmower engine on it load it with some c4 and fly it into the lake.
    Then since I was on a repair binge manic episode go to find the spark plug that has the adaptor ring on it, so
    it fits the hole and I can't find the spark plug.
    3 hours searching and I can't find the plug.
    so I cut the field wednesday flew the nexstar and 2 deadstick landings, motor cuts out at low idle.
    set the idle and she was running good a little rich lots of fuel spraying out the pipe.
    Can't get the OS fx 46 to idle and now she's stalling.
    Put new oring in the low speed needle cleaned the fuel tank and replaced the rubber stopper, and new fuel lines, new glow plug #8 os,
    and then go to fly Friday and can't get the pos to run now.
    flew about maybe half tank and then stall.
    Need tip on cleaning carbon off piston tried seafoam and it didn't dissolve aANY OF THE CARBON !!!
    I'm King of the deadstick landings now.
    Help, seems like more fixing then flying.
  25. #225
    Join Date
    Oct 2010
    Vidalia, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Repaired fuselage, cleaned carb checked diaphraghm and made some new gaskets.
    Found sparkplug in socket.
ID:	1616868   Click image for larger version.
ID:	1616869   Click image for larger version.
ID:	1616870   Click image for larger version.
ID:	1616871   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
