S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
looking for cox 049 or speed 400 spad plans
Reply
Old 07-28-2011, 12:45 PM
nitroairplane
nitroairplane's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default looking for cox 049 or speed 400 spad plans
hi im looking for speed 400 or cox 049 spad planes i really would like something like and extra made of coreflute but please post what you got.
Thanks.
nitroairplane is offline
Old 08-03-2011, 08:41 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: looking for cox 049 or speed 400 spad plans
You could just trace a foamy Extra and make it from coroplast or just use a foam one. There are lots of plans online for those. Crazy Herb has a website with a foam delta. I don't have the link but it is easy to search. It isn't pretty but worked ok on the video. Super cheap. ( a nose heavy plane flies badly, a tail heavy plane can be way out of control. YEHAWW)
aspeed is offline
Old 10-13-2011, 12:41 PM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, a couple of months passed, Did you make one yet?  No one else answered the thread.
aspeed is offline
Old 12-25-2011, 03:15 PM
nitroairplane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry I did not get any reply notifications but I will be trying to build a little extra 300 with not a cox .049 because I came into possesing a norvel big mig .061 that throttles better and smoother and has more power.
I will first try a 6x3 or a 7x2 if I can get one.
It will probably have about a 30" wingspan.
Old 12-25-2011, 09:00 PM
Clean
Clean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is a better engine AND you can get parts for them if you look in the 1/2A forum of this BBS there is a supplier of new parts, or there was half way through the year when last I looked.  Everything Norvel up to and including .25's in parts and engines.  So you is set of good engines and parts.  I always loved the cox engines but hated the fact that just as I got everything working good, it was time to reset that stinking ball joint and blammo, I'd ruin the engine.  I know folks that know how to do it good though, just a matter of patience, practice and better then moose like reflexes.  So, failing all three I swapped to Norvel where there isn't any stinking ball joint!  I just say no to those Cox suckers.
Still, don't get crazy and build light.  There is a little cox bipe on youtube by user named xjet.  Take a look at that and what it does and remember with the Norvel you'll have about twice the power  as the sure start he has.  Won't make any difference in the glide ratio with a lot of weight though, so think light!
Clean is offline
Old 01-03-2012, 08:16 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a Big Mig .06 to replace an .049 Norvel on my Herr Aquastar.  The .049 didn't have enough power to take off from the water. It flew good from a hand launch though. The .06 seems to have enough power but doesn't idle really at anything below full throttle. Rather than go swimming I think I'll just go to the darkside on it.  (electric) or fiddle with it a bit more.
aspeed is offline
Old 05-12-2012, 06:57 PM
Bugzidor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Probably, you may like my coroplast combat wing with Cox .049 sure start diesel, simple design and ease build 2ch.
Bugzidor is offline
Old 05-13-2012, 12:41 PM
Clean
Clean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats SWEET!
Clean is offline
Old 05-15-2012, 08:56 AM
PatrickCurry
PatrickCurry's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What are the dimensions on that Bugzidor?  I agree with Clean, mighty nice!
PatrickCurry is offline
Old 05-15-2012, 10:48 PM
Bugzidor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Span 65cm
Cord Root 22cm., Tip 14cm. Thickness 10%
Fully symmetrical airfoil
dihedral only at bottom of the wing.
Wing area 11.70 dm. Sq.
Wing loading ~ 22.2g/dm.sq.
Fuse length 35cm.
Fin area 64cm.sq.x2ea.
COG 20-23% @ root
Control 2ch. Elevon mix
Probably, you may like to see, how it flies, but, it's not so fun at the end..[:@]
http://www.youtube.com/watch?v=U23fY...hannel&list=UL
ID:	1763106   Click image for larger version
Bugzidor is offline
Reply
Display Modes
