S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
1200 mm Coroflute FPV platform
Reply
Old 12-10-2012, 09:08 PM
nickatredbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1200 mm Coroflute FPV platform
1200 mm Wing span280 mm cord14% Clark Y Plane Calcs Arduino Xbee Remote Control Motor test dataMaiden FlightThe RX codeThe TX Code
The scratch built remote Arduino Xbee very simple code, flys well and totaly customizable Gyro Stability Demowill try to take some FPV video next flight
Test VideoAUW 1521 Grams Wing loading 14.83 oz/ft² power to weight 270 Watts A Kg should perform much better than Yellow plane one.
Missing battery and camera box have a design which should weigh 140 grams empty.
The assembly shown below weighs 684 Grams no motor or electronics.
Electronics shown weigh 110 grams ESC Arduino board, Xbee, antenna and Gyro board
Motor & prop another 120 Grams
Electronicskiwitricopter.blogspot.co.nz/2012/11/building-arduino-receiver-yellow-boats.html
[youtube]http://www.youtube.com/watch?feature=player_embedded&v=EROBU5jMAWo[/youtube]
Maiden Flight[youtube]http://www.youtube.com/watch?feature=player_embedded&v=iwdTw9S8-HI[/youtube]
MK1kiwitricopter.blogspot.co.nz/2012/11/it-flys-maiden-flight-of-yellow-plane.html
Mk2kiwitricopter.blogspot.co.nz/2012/12/yellow-plane-2-with-inverted-v-tail.html
[youtube]http://youtu.be/-LRjqKqUy8s[/youtube]
Yellow Boat
nickatredbox is offline
Old 12-19-2012, 04:23 PM
DESERT RATT
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 1200 mm Coroflute FPV platform
That may be "very simple code" but its over my head. I can read and work with a Schematics but this is cool. I like your ideas and respect your knowledge.
DESERT RATT is offline
Old 12-19-2012, 10:08 PM
nickatredbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the complement.
I suppose you are right about the code if your not code inclined it looks like nonsense If you are interested in coding Arduino is a good place to start lots of code on www
What I want to do is a programmable addon device like a Wii or KK baord that works along with a standard remote as they are so cheap and well proven. The Xbee's ar quite expensive
Old 12-20-2012, 10:08 PM
DESERT RATT
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An I pod controlled Airplane... lol Well. They have the small helicopters that can do it.
Nick, With what you have there, What kind of range could you expect?
Anda question, Why did you go 12MM anstead the 4MM? You could have saved weight so the motor you have now would give you better performance? I'm sure the 4mm would work very well fot your use. 4 on the bottom of the wing and 2mm on the top. Have you checked out www.spadtothebone.net ? It has lots of plans for Spads.
It's going to be pretty neat watching this progress, Best of luck.
Ratt
Old 12-20-2012, 10:43 PM
nickatredbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
The Coroflute as all around 4mm all over its around 5 grams a dm² I have never seen 12mm Coroflute?
The version 2 plane is here
Electronics shown weigh 110 grams ESCArduino board, Xbee, antenna andGyro board
Motor and prop another 120 Gram
