S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
spad weight
Reply
Old 02-09-2019, 04:49 PM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4 AA flat pack. Just from the dollar store. I smacked it up in the fall. Antennae wasn't up on the transmitter. Could have patched it but I have another similar one with a TTiger Pro .40 and a few others to try. It has to be a flat pack because the downspout is cut away for the wing, and it is kind of thin there. That is where it broke too. It is pretty heavey. At about 1/3 throttle it can fall out of the air. Full throttle goes pretty fast for me, it is a very small wing for a .40 and lands pretty hot. 39" x 11" wing and 4 lb. 7 oz.
aspeed is online now
Old 02-10-2019, 02:11 PM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, found a $10 AA NIMH flat pack on Amazon. 2000 mAh. More than what I think is necessary, but the price was right.
Tom Nied is offline
Old 02-10-2019, 03:53 PM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another old pic. I think that is the receiver in, not sure if the battery is in that pic. Don't think so. This is the thinner Canadian downspout. A bit more cramped.
Old 02-10-2019, 05:58 PM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They like to break at the hole, don't they? My first Debonair crash broke the fuselage at the opening. Second fuselage I reinforced it between the wing hold down dowels with yardstick pieces epoxied spanning between them. Extra work, but it never broke there again. Now the wing.......
Tom Nied is offline
Old 02-12-2019, 03:23 PM
ETpilot
ETpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
‘I don’t like rubber bands, so I modded my Debonair for a bolt on wing. Four bolts hold it on. So much better for me.
ETpilot is offline
Old 02-12-2019, 03:29 PM
  #31
ETpilot
ETpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is just FWIW. I’ve been considering coroplast as a lightweight sheeting. I never got to experiment. However I needed an insulator material in a project and I used 2 small pieces of coroplast. They worked good for my needs but were too thick; 4mm. So I decided to cut the coroplast in two.
I had made a small Mickey Mouse foam cutting bow. Just put together, not glued and a bit flimsy. I added a wire heat regulator using my power supply. I cut 2 good sides out of one piece of Coro. I cut parallel to the flutes and it cut easy.
Now when I have time I need to practice with a wing size panel. Also try cutting perpendicular to the flutes. Maybe it might work for a wing.
ETpilot is offline
