Where the SPAD meets the Balsa
My Feedback: (12)
MS
I crashed the heck out of the main wing on my Hobbistar .60. I debated using an old Avistar wing but it really is just too small for an overwieght epox bomb. So, I made a coro main wing for my balsa plane. Surprisingly, it flys fairly well. The plane has been a littly squirly since breaking the fuse in half and tearing off the entire tail section. A few gallons of epoxy and 789 ice cream sticks later it still flys. Here's a couple pics of the new wing. I may go ahead and make an all spad plane eventually, or I may just fly this til it dies lol.
PA
RE: Where the SPAD meets the Balsa
No reason a SPAD wing shouldn't fly just as well as the balsa one. I'm not 100% sure, but in looking at your pics, it appears that you may have creased the top of the wing at the spar. In the future, I would suggest that you NOT crease it, but instead just let it takes its natural shape. Originally the SPAD wings were creased, I believe, but it seems that the creased interrupted the airflow over the top of the wing. Once a "rounded" (for lack of a better tem) wing was tried, the results were such that almost no one is creasing wings anymore. Actually, the old-timers recommend against it - I think. I build all of mine without the crease and they all fly quite well.
Good luck,
Good luck,
My flying buddy totalled his Avistar wing so we mad hime a SPAD wing. This setup worked very well until he finally dirtnapped the plane a few flight after his solo. The balsa/ply fuse is totaled and the wing is OK
My Feedback: (12)
MS
Any suggestions on how to avoid the crease on the next one or if I re-do this one?
PA
Like ChrisSpad suggests, do NOT cut any of the flutes. Instead, with a small phillips type screw driver and a good straight-edge, you simply score (crush) the flute. But, instead of running the flutes span-wise, it is often recommended that you run the flutes chord-wise and score where you need to. By scoring the flutes chord-wise, you should get a fairly nice rounded LE (it will take some practice to get it right) and as you clamp the TF down, a nice wing shape.
Take a look [link=http://home.comcast.net/%7Etipstrickslinks/tip_wings.htm]here[/link] to get a little better idea of what we're suggesting. Building SPAD's is a bit different in some aspects than building with conventional balsa. The link above should giv eyou a better understanding. If not, ask and we'll be happy to offer all the help we can.
Good luck,
Good luck,
My Feedback: (12)
MS
I got it now... I'll know better on my next one or even if I rebuild this one. I had no clue lol. Guess I should have read up a little more rather than just sitting down, cutting and glueing. Thanks all. It does fly pretty funky now. If/when I get the SPAD fuse ready to go I may just make a new wing and scrap my first mistake.
PA
One of the greatest things about Spadders is their willingness to help. If you run into a problem, there is lots of experience to draw from. If you're thinking about doing something and you're not sure about it, but want some opinions, there's lots of those too. Spadders are a great bunch of folks from all over the world and with a vast and varying amount of experience. You'd have to be crazy not to tap these resources for help with Spad's, engines or just RCing in general.
Just my .00019998746,
My Feedback: (12)
MS
Well my first attempt at a spad wing was less than ideal but it does fly. Just from some of the info in this post I'm sure I can do better on the next one.
In fact, I'm even planning on converting the whole plane over to spad now. I caught a nasty cross wind on a take off from about 3 feet and cart-wheeled. It bent the tip of the coro wing a little which is where the brunt of the impact was. It snapped the balsa vertical stab almost in half just from touching the fear of hitting the ground.
Me likem coro - crashem hard an no break! GO CORO!!!
My Feedback: (7)
MO
SPADS BOUNCE!!!!!!
Make an all coro plane.....takes the pucker factor outa flying.....whether ya are just learnin' or whether ya have lotsa experience.....
Cheap too.....and........
NO TOOTHPICKS!!!!!!!!
