Finished my UltraSPADStick!!
SC
After 3 weeks of work she is finaly done!
My 31CC UltraSpadStick turned out great, THANKS KRAUT, flies like its on rails and the 20 mph winds we had Tuesday didnt even phase it LOL.
Here a few pics for those interested.
Not bad for my second SPAD and first gasser eh?
Ben in SC
PS. Go here to see all of the pics: http://www.andersoncountysc.org/MIS/ben/stick
Ben in SC
My Feedback: (16)
RE: Finished my UltraSPADStick!!
Ben,
What an excellent job you have done on this plane. And just think, it uses a conversion engine too.
For those of you that don't know, the complete plans and construction article for this plane are on the net. (Spad site)
Thanks for sharing this with us.
This was originally posted in the conversion engine forum but was moved here to SPADS.
Jim
Jim
SC
Actualy the original Ultra Spad Stick was done by Kraut. Plans are posted on spadtothebone link=http://www.spadtothebone.com/SPAD/ultraspadstick/index.html]HERE[/link]
Ben in SC
Ben in SC
That is exactly what I'm shooting for. Bought the ryobi weedie and am breaking it in on my yards. With the help of my sixth grade class I am going to begin building the Ultraspdstick asap. How did you convert the ryobi? Did you buy the parts or machine them yourself. I have access to a machine shop and would like to make the conversion parts myself. I can only hope we come close to what you have! Very nice!
Tommy
ps Post another pic when you get her stickered up. Please!
Tommy
Ben
Very nice I hope to start one soon. Coro shipment Harborsales has made it to San Diego, now the hard part coming South.
Will 2" long 1/4" nylon bolts secure the wing? (Original h9us120 uses longer bolts.)
Any advise for the first time builders?
What is the finished weight?
GA
Very nice, Ben. I'm on my way to Harborfreight to buy a 31cc Ryobi, and I may have to build a Stick, too! How is the vertical performance? Did you have to add any tail weight?
SC
tommy simpson: I bought the conversion kit from Paragon Aero around $100 for everything needed. I did take the flywheel to a local machine shop to be ground flat. The Paragon adapter wont work with a stock flywheel.
mikenlapaz: Yes I used 2" 1/4X20 wing bolts, the rear ones were actually cut down to about 1". AUW came in at 15 1/2 pounds!!! [X(] Alot heavier that I wanted but was to be expected, I used a little larger peices of wood for the spar and fuse stringers.
AIRPLANENUTS: It has no where near unlimited vertical due to the weight. Maybe if it had a 45cc
512 CES: To heavy.
Oodles: Where do you fly in Central? My club, Tri-County RC has a field in Central at the old landfill. We only fly there once a year or so though. You should come down and visit us one Sat morning.
Ben in SC
PS. Here are a few shots at the field Sat morning. I stil need to finish the graphics but you get the idea of how it will look. Thanks again Kraut!!!!!
512 CES: To heavy.
Ben in SC
GA
Wow, I love it. However, the weight concerns me. Would different wood make much difference? I want to build one, but I'd like to use a Ryobi 31cc.
The color scheme is cool. Should be easy to see! Thanks for the info, Ben.
SC
Mine did come out heavier than it was supposed to. I used some lattice material from Lowes that was 1/8 X 1 1/2 X 8, this stuff was heavy but cheap. I think my next one will either be all yard stick or a lighter wood. Trust me though the weight doesnt hurt this plane other than in vertical performace, it hovers for 10-15 seconds anyway. Even on dead sticks it glides forever.
Ben in SC
Ben in SC
SC
It's a Ryobi that I pulled out of a junk pile at the local small engine shop. I got 2 of them actualy and after replacing the diaphram in the carb they ran great!! Now I have 3 McCulluchs to get rid of
Ben in SC
Ben in SC
