corro to a new level
I love Combat even more since I have discovered Corro. But the look was not always pleasing to the eye, Like most I started off with the simple designs and had great results as far as durability was concerned. Then one day after running out of spray paint I used house paint with not too much success. It came off the plastic I tried sanding it to help make it stick but the finish got worse [very rough] what to do? My friend Ted was using bristol board instead of balsa to sheet his foam wing so I thought why not, after all house paint sticks to paper and well you be the judge.[img][/img] As time went on I got better at copying the scale pannel lines. I start at the rear of the plane and work forward, use Spray 77 on both plane and card stock [your printer type 8.5X11] thankfuly the real planes didnt involve too many complex curves and you can reproduce very faithful panel lines with this method. After painting you rub with 120 grit sand paper and the edges of panel lines "weather "A little air brushing and you too can have one of these beauties Now I know a lot of you are going to say that's too much work for a combat plane but remember these are Corro and take a lot of abuse with little or no damage. My Spit is 6 months old an antique in the combat world and has numerous mid airs under her belt and still looks great, by the way it is one of the Spits from Mike Allen, mentioned in the artical in You won't belive its Corro thread. The Ta 152 is a new desin and proving to be very good at grabbing streamer here in the Great White North I hope I have inspired some to give it a try, its not that hard and the results are fantastic and you WONT BELIVE IT CORRO!!![img][/img]
MT
RE: corro to a new level
Really nice looking planes, canadianice. Really nice!
If you've been flying your Spit for 6 months, I betting they must fly as well as they look.
What I ment buy new design was it is new for me. And yes they fly terriffic the ta grabed 4 in 2 rounds yesterday not bad for her maid'n flight.
I meant nuthin by it, just providing information His was coro as well. Lemme see if I have the link....
http://spadworld.net/combat/bachan[1].zip to download his or go to this page.....
http://spadworld.net/combat/shreddy.html - Shreddy is Eddy Starling, a local (Hawaii) combat flyer and Secretary of Aloha State radio Control Club.
