S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Starter Adapter
Old 04-23-2004, 11:35 PM
Cjsworks
Default Starter Adapter
I saw somewhere a starter cone that fit into a standard cordless drill to start yoyr engine with. Anyone know where to get these? Or can you buy a replacement one for a regular starter and use it?[&:]
Old 04-24-2004, 08:22 PM
rduncan
Default RE: Starter Adapter
I see them on E-Bay all the time. I recall they were $15
Old 04-25-2004, 02:26 AM
Henry_90lx
You can also buy a replacement cone for a torque master starter and then just put a bolt thru the hole in the bottom of it then run a nut up the bolt and !QUOT!sandwich!QUOT! the cone in between the head of the bolt and the nut then chuck the end of the bolt up in the drill. It works pretty good. I use that set up when I am at home and I just use my reversible air drill and it spins up any motor I have pretty good even my 45cc.
Henry
Old 04-25-2004, 12:37 PM
Cjsworks
Where were you able to find the replacement cone? Ive had no luck locating one.[]
Old 04-25-2004, 02:06 PM
ChrisSpad
http://www2.towerhobbies.com/cgi-bin...?&I=LXL400&P=7
http://www2.towerhobbies.com/cgi-bin...&I=LXBC74&P=ML
that and a 5/16" nf bolt and nut are all you need. I have one i use in my 18v ryobi drill. The cone and insert should be available at your LHS, at least they are at mine.
Old 04-25-2004, 06:54 PM
Henry_90lx
That would be the items needed. And yes they should be available at the LHS like Chris already said.
Henry
