S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
SQUARE PVC IDEAs
Old 03-10-2005, 09:52 AM
-pkh-
-pkh-'s Avatar
Default RE: SQUARE PVC IDEAs
When I went to my local store I got this...
Me: Do you carry 2.5" square PVC gutter pipe or downspout
Clerk: No, all that we have is on the shelf there (points to the fluted stuff)
Me: Can you order some for me.
Clerk: Nope
Me: That's odd... it was on your web site...
Clerk: Oh... ask (owner/manager's name) to see if he can get it for you...
The owner/manager spent all of 2 minutes plugging it into his order terminal, an then told me it would be there in two days... and it was!
I didn't come in with a printout of that downspout page, if I did, I wouldn't have gotten the runaround from the first guy... it's hard for them to argue that you can't order a product that's on their website!
Old 03-10-2005, 07:31 PM
RC-Captain
RC-Captain's Avatar
I will wait to see if you get before I try ... Actually I will call now and do you have to buy the entire box?
Old 03-10-2005, 10:54 PM
jlank
jlank's Avatar
I got the same response from a clerk at my local Do It Best hardware store. Talked to the manager and he knew exactly what I was going to do with it before I even explained. Funny thing is I hardly ever see any spads at my flying field. But there is another one just down the road from the hardware store.
Old 03-10-2005, 11:12 PM
RC-Captain
RC-Captain's Avatar
Just continuing to move along....
Old 03-10-2005, 11:57 PM
-pkh-
-pkh-'s Avatar
ORIGINAL: RC-FIEND
That exchange occurred about 4 months ago... I did get it and have built several SPADs with it already!
Like I said, the manager said it would be there in two days, and it was...
I ordered only two 10' sections of it...
Old 03-11-2005, 12:06 AM
  #31
RC-Captain
RC-Captain's Avatar
Give me the number to the store and I will call and order myself 5 10' lengths.
Old 03-11-2005, 12:24 AM
  #32
-pkh-
-pkh-'s Avatar
Sure, if you want to drive to Emmaus, PA to get it... you should just call one of the four stores that you said were in your area and order it!
Drie's Doit Center
3580 Brookside Road
Emmaus, PA 18062
(610)966-5555
Like I said, there's a DoItBest store in Newark and Staten Island, both of which should be closer for you than hauling out here to PA. Hit that link I had in my previous post and plug in your zip code, pick the store most closest to you...
Old 03-11-2005, 12:31 AM
  #33
-pkh-
-pkh-'s Avatar
Here's the listing I get when I plug in an Elizabeth NJ zip...
Garber Building Supply
98 Greenfield Avenue
Staten Island, NY 10304
1-718-447-2122
Pando Hardware & Plumbing Inc
132-134 Bloomfield Ave
Newark, NJ 07104
1-973-483-6867
Active Lumber
6119 7th Avenue
Brooklyn, NY 11220
1-718-492-5000
Garber's Do it Best Hardware
4890 Arthur Kill Rd
Staten Island, NY 10309
1-718-948-9495
Dick's Do it Best Hardware
205 Pearl Street
New York, NY 10038
1-212-425-1070
Old 03-11-2005, 01:13 AM
  #34
RC-Captain
RC-Captain's Avatar
I did call but they didnt have it and I doubt very much they will order it. This the city, all personalities are different.
Why would I have to drive to PA all I will do is have him box it up and have feddex pick it up for me. If no too expensive.
Old 03-15-2005, 06:54 PM
  #35
RC-Captain
RC-Captain's Avatar
Hi again, I completed the servo bays and beleive using the smaller cutting wheels is much faster than using the thicker cutting wheels. Also much more neat.
ID:	244452   Click image for larger version
Old 03-16-2005, 09:07 AM
  #36
Bryan H.
Fiend,
You should have gotten the Black ABS Pipe instead of that sch 40 PVC stuff. The Black ABS pipe is about 1/3 to 1/2 lighter with more rigidity and the same wall thickness. It is sold as DWV pipe (Drain Waste Vent).
Old 03-16-2005, 06:16 PM
  #37
RC-Captain
RC-Captain's Avatar
Thanks, I made this post topic just for the reason you are telling me about the black pipe. If you posted sooner I may have bought some. Anyway some one else can benifit from the information. Do you have a pic of what yoyu are talking about ? this will help a new SPADER if he or she goes to look for some of the black pipe.
Today I found something else, I was working and came across a hardware store in a small town and asked for the 2 1/2" square vinly pvc and the guy said he didn't have anymore [:@]. I'm going to continue, while also trying other material to use for a fuse. Hopefully other people can benefit from the stuff I find.
Old 03-17-2005, 10:12 PM
  #38
RC-Captain
RC-Captain's Avatar
Time to balance.............
ID:	245460   Click image for larger version
ID:	245461   Click image for larger version
Old 03-26-2005, 10:10 AM
  #39
RC-Captain
RC-Captain's Avatar
Last weekend I tried to fly , but the engine wouldn't run properly due to low pressure and a crack in the back plate gasket.
I repaired the gasket and swiss cheesed the plane some more and also re-balanced...... Pic is of how it presently looks before todays flight.
[img][/img]
All up weight is 6.5 lbs.
ID:	249282   Click image for larger version
Old 03-26-2005, 02:09 PM
  #40
MrGreenSpeed
At that weight it should fly great.
Good luck on your next flight attempt.
Jeff
Old 03-26-2005, 04:54 PM
  #41
RC-Captain
RC-Captain's Avatar
Thanks Green, I couldn't get the thing to leave the ground. I think my .40 is finished. It just doesn't seem as powerful as it use to be. Tonight I will try to bring the weight down a little more and stabilize the nose gear . The way it is mounted now there is to much wobble when trying to ROG. I even had the flapperons down and it didn't break ground . I just laughed and put my trainer in the air to get my flying fix.
Any way after seeing a guy trying to fly a foamy electric in 10 mph winds was all I needed to make my day .. Poor guy threw it in the air 15 times only to get the same result. Oh well I guess he will learn like I did ..
Old 03-30-2005, 11:28 PM
  #42
RC-Captain
RC-Captain's Avatar
I HAVE FOUND IT !
I came across a hardware store today and it had a DO IT BEST sign in the window . I wasn't going to stop and go in but I couldn't resist. So I got inside and didn't even see the aluminum downspout, which the store clerk called the 'leader pipe' . So then I asked the clerk for the vinly stuff and he went into the back to ask somebody if he could order some and then he cam back out and told me he could get the pipe , and it would cost me $14.00 . See I knew in due time I would prevail with out the all of the aggrevation of having someone mailing it to me.
Old 03-31-2005, 12:44 AM
  #43
MrGreenSpeed
Cool, just remember to ware a dust mask when cutting PVC pipe.
Jeff
Old 03-31-2005, 01:18 PM
  #44
-pkh-
-pkh-'s Avatar
Yep... I actually bought a respirator at Home Depot... it has replaceable filters and an exhale valve, so you don't fog up your glasses (if you wear them). I wear it when I'm cutting PVC or spraying paint with my airbrush. I look something like Darth Vader while I'm wearing it, but I never wear it in public, anyway...
I also bought a cheap 20" box fan and a 20" 3M Filtrete AC filter to tape to the back of the fan. I run this fan full blast next to my work area, filter towards me, to suck up as much dust or overspray as possible... makes cleanup a little easier and keeps airborn particles to a minimum...
Old 04-06-2005, 08:10 PM
  #45
denney47
My Feedback: (359)
I can get all the 2-1/2" square PVC downspout I want, I can also ship it to you. Let me know if you want any. [email protected]
Old 04-06-2005, 08:47 PM
  #46
RC-Captain
RC-Captain's Avatar
Will do Denny and thanks, first I want to see what I get from the guy I ordered the pipe from. Should be in this Friday.
Old 04-06-2005, 10:06 PM
  #47
rccrasher1967
rccrasher1967's Avatar
found out about RCU and cant get enough ! The down spout your talking about , is it smooth or does it have dips in the sides ,is it square or rectangular and is it kinda flimsy or stiff? Went to Lowes other day and all they had was the kind that had dips and was flimsy . I am trying to find something that I can crash with out putting alot of money into
Old 04-06-2005, 10:17 PM
  #48
RC-Captain
RC-Captain's Avatar
I'm not sure yet , I have seen vinly downspout that is rectangular in shape and has the dips in it. It was expensive too and very flimsy. I will know once the hardware store gets the shipment and I go pick it up . Just another thing added to the 100 things I have to do on Saturday [], before I go fly.
Old 04-07-2005, 05:10 PM
  #49
RC-Captain
RC-Captain's Avatar
Just a follow up I HIT THE MOTHER LOAD ...........[X(][:-] . Today while on my way to my next service call I stopped at the store to check if the pipe came in and sure as s**t it was there. The funny thing is the guy told me he had it all the time in the warehouse which is in the back of the store not connected to the main building. Who would have ever guessed. $28.00 dollars for 2 lengths is a steal IMO. Here's the pic of the pipe , he also has brown . When he told me he had it all the time , the amount of planes I could have finished ran through my head. I then said "ok , now which one of you do I have to take my belt of for ?" he laughed and then I paid him. For some reason these guys working at this hardware store seem strangely nice . I guess they are making a bundle from what they are selling. Hey if they had square pvc pipe , after some of the biggest stores didn't , They must have everything a person would want. .
Old 04-08-2005, 09:05 PM
  #50
rccrasher1967
found corplast finley .local sign shop has some 4x4 .4mm sheet signs that a guy orderd a couple of years ago for a election campain .another place i want to check is the local demacrat and republacan offices maby they will have some old signs.about the down spout i found will it work ?or should i use coro ?
