S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Which Thickness of Coroplast ????
Reply
Old 05-23-2005, 03:32 PM
JettPilot
JettPilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Which Thickness of Coroplast ????
I am building an EPP mothership and putting a Zenoah G-26 on it. I am going to use Corroplast for the engine mount and need to know what thickness of coroplast it would take to be strong enough to mount a G-26 to. With this much power weight is NOT a concern, but streingth is !
What thickness of coroplast does US aircore use for a 40 sized plane fuselage ?
JettPilot is offline
Old 05-23-2005, 03:51 PM
tamccain
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Which Thickness of Coroplast ????
I don't think it is wise to use just coroplast for your engine mount. I don't think you will ever get the strength or rigidity from coroplast that you will need for the engine mount. You should use something like the plastic cutting boards, or wood, or even some steel, but I don't think the coroplast would be a good idea.
tamccain is offline
Old 05-23-2005, 04:48 PM
rsieminski
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Coro is not for engine mounts. 2mm coro for most wings, 4mm for most fuse's. HDPE for most engine mounts. Nothing is set in stone, but if you use coro to mount an engine, someone will end up in the ER.
rsieminski is offline
Old 05-23-2005, 05:33 PM
ChrisSpad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
not to mention the coro melting.
ChrisSpad is offline
Old 05-23-2005, 06:42 PM
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I feel you can use coro if you cover the parts where the engine touches the mount with CA covered balsa. This way it won't melt the coro when hot and you will save on weight. Of course you know the CA is for fire proofing the mount and fire wall. GL
RC-Captain is offline
Old 05-23-2005, 08:53 PM
jpr72c
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out the pics in "My First Gasser" thread. I mounted a G26 on 1/2" plywood and it works great I'm now a believer in coro fuse - very strong and lite. I had used gutter pipe in all my other spads!
jpr72c is offline
Old 05-23-2005, 10:09 PM
voyager_663rd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RC-FIEND
coro won't hold the weight, especially a g26. use balsa to support it? bah. that balsa IS your engine mount. would you use balsa as a mount ANYWHERE? Don't think so.
voyager_663rd is offline
Old 05-23-2005, 10:31 PM
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree , I wouldn't use anything but a regular die cast metal or what I think is carbon fiber plastic engine mount. But I must guess he must have seen a coroplast mount before which leads me to believe this why he is asking about the thickness of the US aircore fuse.
Reply
Display Modes
