ARF Spad
#51
My Feedback: (7)
CA
RE: ARF Spad
Horizon and Gdenton, thanks for your replies and website address for fx hobbies. Went there and found more details on their product line. One other question I have is how tough are these things? I am primarily looking for something that flies decently and is easily repairable. I know nothing is indestructable, and assume the wing is the weakest part of the airframe. Can they be repaired if bent or do you just buy another one? Am looking at ordering the cirus fuse with the 56 inch wing and using a TT.46 with standard servos. Think the bigger wing would bring the wing loading down under 20 oz./sf if your 4 pound dry weight is correct. Thanks, Joe
#52
TN
RE: ARF Spad
My cirus took a flight into the woods, you can see the pics in the crash section. Broke the firewall, prop, and tore the wing in half. Everything else was fine They are very repairable even if you break the spar. Duct tape backed up with ca glue works well to repair the wings. I think a 56 inch wing on the cirus is a bit over kill, I would get the standard wing with it also so you have options at the field. I always get funny looks when I unload two planes and 4 wings
#53
My Feedback: (7)
CA
RE: ARF Spad
Thanks Horizon, want the longer wing to reduce the wing loading, so maybe I'll just go with the e-z flyer and a flat 56 inch wing. Think this will come in at 4 lbs with a TT. 46, 4 standard servos and 4.8v 600 mah nicad?
Thanks, Joe
Thanks, Joe
#54
TN
RE: ARF Spad
ORIGINAL: garch 22
Thanks, Joe
Thanks, Joe
#55
AR
RE: ARF Spad
ARF FLYERS,
Thanks for all the great comments regarding our FX-Planes. They are much appreciated. At the present time, we're working on our web site to make it more informative about our planes. We appreciate your patience with us. If you do need to reach us, contact us through our email address: [email protected] , or for a quicker response, please give us a call at 501-984-5826. This past week, we have weighed some of the planes that we have and according to our scale, here is what the planes weigh, including landing gear, before any equipment is added.
FX-FIRE FLY 34" W/S = 1 lb., 6 oz. ... Combat plane - no gear.
FX-TYRANT 48" W/S = 2 lbs., 6 oz.
FX-CIRRUS 48" W/S = 2 lbs., 3 oz.
FX-EASY GOER 56" W/S = 3 lbs., 3 oz.
FX-BANDIT 48" W/S = 2 lbs., 5 oz.
FX-B.U.F.F. STIK 80" W/S = 4 lbs., 2 oz.
**Note** Add about 2 - 3 oz. if the plane has a dihedral wing ... the FX-B.U.F.F. STIK 80" W/S does not have the dihedral option.
Here's a couple pictures of our FX-FIRE FLYs that we'll be adding to our web site shortly. The FX-FIRE FLY is a combat plane and has a 34" W/S, a 24" fuselage, and takes a size .15 or .25 engine.
Thanks for all your support,
Mr. FX
[img][/img]
Mr. FX
[img][/img]
#56
My Feedback: (13)
MD
RE: ARF Spad
Hey FXHobbies, welcome to the site. Glad to see you here
I just wanted to give everybody an update of my Tyrant. Got about 20 flights on it now and the Super Tigre .51 is breaking in and getting happy. This airplane is nothing but fun!!!!
This is my favorite out of all of the Spads I have gotton from FX and I just ordered a black one as a backup.
My club just ordered about 20 assorted Spads from FX Hobbies to do a club Spad build at our November meeting. Once we have the airplanes all assembled, we will create a fun fly event around them.
My Tyrant-[sm=thumbup.gif][sm=thumbup.gif]
#58
RE: ARF Spad
my spad is a fxhobbies tyrant
I have a .48 msd and its off the ground in about 10 feet.
The only problem I have is ground control but that might be me.
it will fly inverted, go vertical untill you can hardly see it.
great plane, I have about 20 flights on it so far and about 3 cart wheels with no damage!
Brad
Brad
#59
My Feedback: (13)
MD
RE: ARF Spad
Fixeruper,
The location of the landing gear is important. If the wheels sit to far forward, it will ground loop and handle very poorly on the ground. I know, I went through this with my FX Hobbies Debut. I cussed a blue streak at that airplane until I figued it out. On my Tyrant the wheels sit slightly to the rear of the leading edge of the wing. I can run the Tyrant around the runway better that an R/C Car! I will put mine up on the bench tonight and get you an exact measurement where the axle sits in relationship to the leading edge of the wing.
#60
My Feedback: (13)
MD
RE: ARF Spad
Fixeruper,
My Tyrant has the the landing set up so the wheel axle is 1" behind the leading edge of the wing. If yours is forward of this location, that may be your problem. If it is to far forward it will also have a tendency to want to bounce down the runway during landings. I experienced that with my FX Debut until I moved the gear rearward.
#63
TN
RE: ARF Spad
I have found that taking off gradually with up elevator till you get to a good speed keeps these planes tracking well. If you slam on the gas you just do some 360's.
#64
My Feedback: (13)
MD
RE: ARF Spad
That was also a problem with mine until I got the gear in the right place. I found on both the Debut and the Tyrant the gear worked far better sitting back farther than you would expect. I can shoot touch and go's and run the whole length of the runway on the deck and take back off now with no problems at all. Before, with the gear forward, it had a bad habit of bouncing, and wanting to stick the prop in the dirt on both take off and landings.
One other minor problem I found also was that the engine on my Tyrant had about 2 degrees upthrust in it. When the firewall was machined it created this offset and on landing it would balloon with just the slightest increase in throttle. A couple of washers behind the engine mount and that problem disappeared.
#69
TN
RE: ARF Spad
I think the easy goer would be a great choice for a nose wheel. Its a big easy slow plane to begin with, and the extra gear would not add that much.
#70
My Feedback: (12)
RE: ARF Spad
I just had a great talk and ordered a FX-EASY GOER from FXHobbies good person to talk to frank ask about the B.U.F.F stick cant wait to hear more on this plane sounds like a cool fun flyer long wing span 80 inch so is that a glider hehehehe just kidding and yes i am going to add training wheels to my EASY GOER LOLLOL our run Way is ruff hard on a tail dragger and no were to take off from grass so front wheel it is.[>:]
#72
TN
RE: ARF Spad
ORIGINAL: layback2
I will be posting a review on a experimental plane from FX. It is a idea that I had, and Frank was nice enough to build it for me. It is a Easy Goer but a low wing, and a longer fuse, going to be called the FX-Star he said.
Will post some pics when I get it.
#74
NY
RE: ARF Spad
Why did the thread just die in October? Anyone fly the Buff?? I see they are now selling them on ebay, and the link abouve for the website isnt working...
[link=http://search.ebay.com/_W0QQsassZfxhobbiesQQhtZ-1]FXHobbies[/link]
#75
RE: ARF Spad
Hello dose any one know where one could get plans for the Tyrant? Or is it just a Fx-Hobbies plane, Is it alot like the Demon? I really like the looks of it and I bet it flies nice .Thanks
