S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
STYRKORO S27
Reply
Old 05-06-2006, 01:46 PM
microsprint9
microsprint9's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default STYRKORO S27
Well here's my second attempt at a SPAD, it's the STYRKORO S27. I loved my parkzone f27 so much and have designed many foamies around the basic shape of the stryker, then i bought a glow motor and since then i have been neglecting my electrics. This has got to be one of the easiest builds i have done, then plane is 90% finished, only some paint and vinyl to make it look like a stryker. My first spad was this same plane without the nose, it was basically a flying wing and flew very good with a 40LA but it was tail heavy so i decided to move the motor forward and use the stock shape of the stryker, i guess i moved the motor too far forward, i needed 5oz of lead in the tail to balance it. I have drawn this plane in cad so if anyone is interested i will post a file. I hope to maiden it next week if the wind dies down a bit. Here are the specs.
Wingspan 44"
Wing Area 580 sq/in including elevons
Wing Load 16.8 oz/sqft
Weight 4.25lbs
Engine OS 40LA
Prop 10x7
Radio Hitec Optic 6
Receiver Electron 6
Servos HS-325HB 3 needed ( 2-elevons, 1-throttle )
Here are some pictures up to now
ID:	456854   Click image for larger version
ID:	456855   Click image for larger version
microsprint9 is offline
Old 05-06-2006, 10:24 PM
FantzyPantz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: STYRKORO S27
I like the design of your Strykoro. Is this made with a single piece of 4mm or do you double 2 pieces of coro with the flutes perpendicular like the BullDawg? I would like to see how you mount the servos, measurements, CG, or Drawings. Did you use anything to stiffen up the wings like carbon rod, or BBQ skewers? It looks very similar to the CoroRoo, found at http://www.spadcombat.com
FantzyPantz is offline
Old 05-07-2006, 01:23 AM
acam37
acam37's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you seen the coro-roo? It is very similar in design. I watched a video of one and with the right engine and prop these things are very fast.
acam37 is offline
Old 05-07-2006, 06:47 AM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry i forgot to mention in my first post that it is just a 6mm pc of coroplast and 2-1/2 x 2-1/2 pvc downspout. I did epoxy a 3/16 dowel in the wing, if you look closely in the one of the pictures you can see it. My prototype was basically the same and it was quite fast with the 40LA, the wings did start to flutter a bit on fast level passes but i'm sure with some leading edge stiffening and maybe some more of those bbq skewers you could make this thing extemely fast. Late yesterday i mounted the elevon and throttle servos and did some painting, going back to my shop right now to finish it off. I'll post some more pictures later on. It might look like the coro-roo, but this plane is 100% built around my first plane, the parkzone f27 Stryker. http://www.horizonhobby.com/Products...ProdID=PKZ1200
Old 05-07-2006, 10:53 AM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Back from the shop, WOW, what a difference paint makes, it's also nice to have a vinyl cutter. All servos are zip tied in place and the CG should be 9"-10" from the back flat part of the wing which is same as my stock stryker, just scaled up. Plane is 95% finished now, only throttle linkage and hooking up the radio gear to go, i might also make a front cowl for looks, but this is simple plastic aircraft design, a cowl will probably be a little bit of work and not so simple. Once i have maidened the plane and exacted the CG i will post plans for all to enjoy. Here's some pictures up to now.
ID:	457419   Click image for larger version
ID:	457420   Click image for larger version
ID:	457421   Click image for larger version
Old 05-07-2006, 10:54 AM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few more.
ID:	457427   Click image for larger version
ID:	457428   Click image for larger version
Old 05-07-2006, 12:51 PM
FantzyPantz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alright, with those pictures you convinced me that I really want to build one of these. It's going to compliment my CoroRoo quite nicely I think. I'm interested in the drawings that you have.
Old 05-07-2006, 08:33 PM
DLSmith2
DLSmith2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great looking ship with an awesome paint and graphics job!
Looking forward to seeing the plans!
Blue skies,
DL
DLSmith2 is offline
Old 05-08-2006, 02:21 PM
Smooth Spanky
Smooth Spanky's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Microsprint9:
Great idea and nice job on the plane! You mentioned only 3 servos (elevons + throttle). Does this mean your nose gear is not steerable?
SS
Smooth Spanky is offline
Old 05-09-2006, 02:30 AM
jamesg25
jamesg25's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks god, great paiont job. perhaps you may want to consider putting clear tape over the leading edge, it should make it fly nicer.
great job,
looking, waiting for flight report.
regards
james
jamesg25 is offline
Old 05-09-2006, 04:10 AM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thnaks for the complimements, i got to fly it last night. I don't have a runway but i wanted gear on the plane to save the prop on landing, so i made the nose gear solid. The first flight went alright, but hand launching this plane was not the best idea, i nosed it in a few times, but on my last try i got it up in the air, i think i still need some more weight in the rear, so the CG will be 9-9-1/2" from the back flat part of the wing. I will draw up some plans today and post them. I think next time i fly her i'll find a runway to takeoff from, and make the nose gear steerable.
Old 05-09-2006, 07:41 AM
Muldoer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since you got it flying, do you think that a .46BB would be overkill on this plane? I have a Sickle with a 40la on it, but I also have an Evo 46NT sitting on a low winger and I since the Sickle flies so great I am starting to have a deeper interest in flying wings.
Muldoer is offline
Old 05-09-2006, 09:21 AM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found the 40La seemed to have more power in the prototype, but it also weighed 10-12oz less, i think a good .32 would keep some of the weight off the nose and allow for less lead to be used in the tail. I think a 46bb could be used but you might want to scale the plans up a bit to lower the wing loading. Plans will be posted very shortly.
Old 05-09-2006, 10:53 AM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay here we go. In drawing 1 layout all the dimensions onto a sheet of 6mm coroplast and cut out. The tail fins are giving me a problem to post so they can be printed to scale, please e-mail me and i will send you a printable .jpg file that will work on a legal size sheet, or on a 8-1/2" x 11" and just improvise the rest, i used 1/2" quarter round to attach these to the wing, triangle would also work. In Drawing 2 cut out fuse from 2-1/2" x 2-1/2" PVC downspout, i used a pc with sides cut down to 1/2" for the hatch. Drawing 3 is the graphics, not sure if the picture is usable to you guys but it will give some reference. Everything was assembled with ZAP CA and zip ties were used for attaching servos, battery and reciever. I used a 3/4" thick pc of ply for the motor mount bulkhead, since this was my first attempt at landing gear i'll leave that one up to you. CG is between 9" and 9-1/2" from the middle flat part of the back of the wing forward. Enjoy, and if you need anymore details please let me know.
Wayne Vanderweyst
microsprint9@hotmail.com
ID:	458630   Click image for larger version
ID:	458631   Click image for larger version
Old 05-10-2006, 09:43 PM
MrGreenSpeed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice set of plans thanks.
Jeff
MrGreenSpeed is offline
Old 06-17-2006, 09:45 AM
FantzyPantz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm bumping this topic, started cutting out the wing this morning, and wanted to come back here for reference. Thanks for the drawings, they are great!
Old 06-19-2006, 10:47 AM
Smooth Spanky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm glad to see this thread moving again...what a great idea. I'll be looking forward to some pictures, especially some in flight (hint hint...)
Old 06-22-2006, 09:55 PM
Gringo Flyer
Gringo Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: FantzyPantz
I have built the sickle and love it. Everyone at the field begs me to let them fly it and so now I really want another flying wing in my hangar.
I have a TT pro 46 with a Tower muffler and I had looked at the CoroRoo but the Styrkoro us pretty sharp and has peaked my interes. So anyone building one of these be sure to post details and pics so I can learn from your mistakes and steal your ideas!
Gringo Flyer is offline
Old 06-23-2006, 01:18 PM
FantzyPantz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got my wing cut out. I didn't have 6mm coro, so I put 2 pieces of 4mm together with the flutes running perpendicular (See BullDawg build). I cut the elevons with a dremel since the coro runs perpendicular. This is the 1st time I have tried cutting the control surfaces this way, but so far I think I'll have a solid hinge. I have PVC gutter, but I'm thinking about forming a coro fuse to compensate for the (Probably nominal) weight gain used in doubling the 4mm. I'll post a pic.
I'm not sure if I'll put landing gear on this or not. Right now I'm thinking of hand launch with a landing skid for dead stick landing. More later.
Old 06-30-2006, 11:28 AM
Dead eyes
Dead eyes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This looks like a great project ! It reminds of a Balsa USA Enforcer. What are the throws. Also what are the dimensions on the rudder. I may try this one in my spare time. Thanks
Dead eyes is offline
Old 07-02-2006, 11:47 AM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry it's been a while since i posted, unfortunalely my la40 just didn't have enough power to fly this plane the way i wanted, i did just order a TT pro .46 so i might try that. FantzyPantz, when i cut my elevons i broke through in a few spots so i just added a layer of clear duct tape to make sure they stayed on, as for the 6mm to 2 pcs. of 4mm the weight differecnce is only .22oz/sq-ft with 6mm weighing 4.34 oz/sq-ft and 4mm weighing 2.28 oz/sq-ft. Dead eyes- just e-mail me and i will send you a file that you should be able to print out for the vertical stabilizers, as for the throws, i would say at least 1" up and down to whatever you can handle. So my strykoro is on the backburner now, but wait til you see the 8' B2 bomber i'm working on, i have already built a 4' e-powered mock up and it flies great, now 200% and glow power.
Old 07-08-2006, 04:12 PM
mgb1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
I make foamy version yours STYRKORO S 27
Wingspan 110 cm
Weight 1100 g dry
Engine MVVS 2,5 ccm
First flight went good but MVVS is too weak Tomorrow i will fly with OS 25.
Hand lounching is very good.
This is very nice idea .Thanks
ID:	488673   Click image for larger version
ID:	488674   Click image for larger version
mgb1 is offline
Old 07-08-2006, 09:09 PM
DLSmith2
DLSmith2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mgb1,
Welcome to the forum! Great looking planes! How did you anchor the motor mount in the foam?
Blue skies,
DL
DLSmith2 is offline
Old 07-09-2006, 02:25 AM
mgb1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for compliment.Foam is 3 cm - styrodur
ID:	488869   Click image for larger version
mgb1 is offline
Old 12-05-2007, 11:23 PM
Wayne H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's one way to do it. You could also just use 1/4" aircraft plywood and mount the engine directly to the plywood. Use polyurathane glue to hold the plywood to the foam. Make sure to add water to your glue joint to insure that the glue will double expand. I put a 25 lb. weight on the plywood when gluing.
ID:	819499   Click image for larger version
ID:	819500   Click image for larger version
Wayne H is offline
Reply
Display Modes
