Different way, same control horn
Cut a slot, put a couple drops of glue on the inside of the horn, poke it up from the bottom and run a screw from the top. Done in seconds.
I'm confused. What are the benefits of this? It looks like you get a slightly shorter control horn and a cut in your coro that might tear. Does look kind of cool though.
One less piece, one fewer step, and you can always make the control horns any size you want them. So far there has been no signs whatsoever of the slot in the coro tearing!
