If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 30
  1. #1
    Join Date
    Feb 2007
    Texas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    homemade electric SPAD
    Ok, so i'm trying to make an electric SPAD with cheap materials and some that aren't hard to find.
    1)I'm thinking about coroplast instead of foam, is that the right thing for an electric?
    2) I also have trouble finding light batteries, for example i have about 8 cells of AA 1.2V (9.6V overall) but i fear they're too heavy for an electric... about 360grams.
    3) I though about mounting them in the fuselage from the nose till the rear so that their weight doesn't pull to a specific point on the plane.
    4) I also have a 10 cell 1.2V (12V overall) battery pack that is heavier than putting the other 8 together.. it's about 450grams. Should i use that instead for extra power, or the plane won't be able to take off?
    My motor can be compared to a speed 400 and might be a little stronger.
    Channels are 4 - throttle, ailerons, elevators, rudder.
    What do you think, give me clues..
  2. #2
    kbear's Avatar
    Join Date
    Sep 2004
    Denton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: homemade electric SPAD
    First, can the the motor handle 12v? I don't your experience level so forgive me if you already know this stuff. Take the volts times the amps the motor can safely draw to get watts. Shoot for 75 to 100 watts per pound. Then you'll have an idea of the weight your shooting for. I'd say your going to fid it hard to come in less that about 1.5 lbs. It's not impossible, but hard. Figuare out the watts of your system, and post them. This will give a better Idea of what can be done.
  3. #3
    Join Date
    Jul 2003
    Carrollton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    With that type if a power system, your best bet for success is to build with 2mm coroplast. A speed 400 type engine without a gearbox is best suited for a plane that weighs no more than about 20 ounces. Adding a gearbox will allow you to spin a larger prop to give more thrust. If you can get your hands on blue core, also called fan fold foam, you could build the Zagi clone called the ZagNutz flying wing. I have built and flown a few Zagnutz wings with a Speed 400, and Speed 480 can motors on both 8 cell and 10 cell AA batteries.
    I would suggest building ZagNutz, a Mugi, or the Dazi. All are good candidates for the Speed 400 electric motor.
    Mugi Plans - http://www.mugi.co.uk/evo_intro.php
    Dazi Plans - http://www.zipworld.com.au/~dazb/dAzi/dAzi.html
    ZagNutz Wing Plans - http://home1.gte.net/texhills/page3.html
  4. #4
    Join Date
    Feb 2007
    Texas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i'm actually trying to built this kind of plane -|-: instead of this <.
    (hope you understood the diagram..
    Anyway, i aim on a 12v 1lb battery pack with a close-to speed 400+ motor.
    All i want to know is if the motor will actually take off the plane at 1.3+lb... I thought about a smaller battery, smaller plane, smaller prop, but i don't know the weight- thrust ratio on planes.
    I estimate the battery pack's power in watts to be close to 75Watts.
    BTW , is the gearbox the thing added to motors to make the prop spin more RPM?
    I'm desperate.. 1.3lbs, 75W what do i do? thanks for your replies.
  5. #5
    Join Date
    Jul 2003
    Carrollton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The gearbox will spin at lower RPM but allow you to use larger prop for more thrust. As for those plans, I figured that they would be the easiest to use to keep the weight around 20 ounces. With a 1 pound battery, building a light plane from coroplast is very difficult. Here is another set of plans you might want to look at. Credit goes to Hangtight for the great set of plans.
    http://www.avoidingtheground.com/spa...e_%20Build.pdf
  6. #6
    Join Date
    Feb 2007
    Texas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So what i finally decided is to change the battery power and prop.
    I'll use a bigger prop with a 6.0V 120mAh battery for the servos and probably 4.5V 800mAh 3cell battery for the motor, maximum 1lb (my SPAD is actually quite different than regular ones because i can't buy a complete radio/servo set, so i have to make it on my own)
    To get the complete picture, imagine a radio receiver (middle of plane) connected to two servos and a small 6V battery pack (all i got) which is so small it would fit someones fist, and 3 AA cells connected together on the motor + a switch. You turn on the switch, prop goes crazy, you fly it with elevator and ailerons and when the batteries die you land it.
    Ok i'm done.
    Thanks FantzyPantz you inspired me to think this. Hope it flies...
    (by the way i'm 16 and i'm currently broke so i can't buy radio gear- i'm also bored , i wanna make this as homemade as possible)
  7. #7
    Join Date
    Jul 2003
    Carrollton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I hate to discourage you, but that setup probably isn't going to fly.
    What part of Texas are you from?
  8. #8
    coolbean's Avatar
    Join Date
    Jul 2005
    liberty, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I hate to burst your bubble here... but 3 cells is 3.6V, unless you are using alkalines which are not rechargeable and are usually a lot more than 800mah so I doubt it. And a speed 400 is going to run like crap on 3.6V. You are too heavy and too slow. If you can get to 9.6V it might fly... maybe...
    A moose once bit my sister.
  9. #9
    Join Date
    Feb 2007
    Texas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You're right.
    It seems i need to research more and experiment a bit before posting for help.
    I'll try other methods and let you know.
    For the time being just let this post die....
    Thanks for your concern, guys.
    Maybe i'll try that Zagnutz design which you say flies with 8 to 10 AA batteries.
  10. #10
    Join Date
    Feb 2007
    Texas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i got one more question, which might be stupid.
    How about i turn the zagnutz design to a regular plane? i mean if you look at it, i think it would be nice if you glued the whole zagnutz on a stick (for example) and put horizontal stabilizers and vertical stabilizer on the end of the stick, to make it look like a regular plane.. would that work?
    By the way are you sure that the speed 400 lifts a 8-10 AA cell battery pack?
  11. #11
    Join Date
    Jul 2003
    Carrollton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Take a look at these types of planes. They are not considered trainers, or beginner planes, but can be flown in a big back yard or park. http://foamyfactory.com/
    B2 Bomber? http://www.pibros.de/sons02_1.htm
  12. #12
    acam37's Avatar
    Join Date
    Jan 2004
    lufkin, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    louis73, if you just want a cheap electric, then it would be better to go to Wal-Mart and check out the Air Hogs R/C planes they carry. For an elecrtic spad you will need a very light power system with a bunch of power. For example, a strong Brushless motor, compatible ESC, and at least a 3 cell LI-PO 11.4V with around 1500MAH. This setup could fly a 2 pound spad just barely. The bigger the motor and battery pack equals big bucks.
  13. #13
    Join Date
    Feb 2007
    Texas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah but checking out planes at wal-mart isn't included in the initials S.P.A.D.
    Updated (edited) part:
    OK guys i just found a 0.25lbs 11.1V LiPo battery pack. With the motor+prop (0.25lbs) servos (0.1lbs) and radio gear comes to a total weight of 0.70lbs. Power supply is 11.1V, estimated power is 80W.
    Here are some pictures of the system.
    GIVE ME FEEDBACK ON THE PROP it's a homemade one (aluminium + foam spinner)
    1.next to my thumb is one of two servos i'll use which is smaller than my thumb's nail
    2.the battery
    3.speed 400 +prop (is the prop too big?)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	629255   Click image for larger version.
ID:	629256   Click image for larger version.
  14. #14
    export!'s Avatar
    Join Date
    Nov 2005
    Skunk Works North - Windsor, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I made this SPAD out of 2mm coro and it flies great. I can look up the plans if you like but it's called a BUGI.
    \"We demand rigidly defined areas of doubt and uncertainty\"
  15. #15
    Join Date
    Jul 2003
    Carrollton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Of those 3 items, the motor and propeller are the only usable items you have for an e-spad and it must weigh no more than about 20 ounces with the battery. That thing that you have next to your thumbnail isn't going to provide enough torque for squat. The battery doesn't look like it would have enough juice to fly anything for more than a few seconds. I'm sorry to discourage you, but if you want to have success with spads you need to start out right. What you have isn't going to do.
    The motor and prop are ok - Speed 400, and 4.5x4.5 prop are great for zagi, speed jets, Mugis, and Zagnutz. Add a gear drive and you can turn larger props and fly slightly bigger planes translates as slower planes.
    You need a Electronic Speed Controller (ESC) for a speed 400 that will be at least a 15 amp controller. ($20-$30)
    Those tiny things you call servos? Nope they won't work on any plane that you plan to fly with that speed 400. You need at least 2 mini servos. ($15-$30+)
    And for the battery, you can get by with 7 to 10 cells for a speed 400. Like I have said, I have flown Zagi, and Zagnutz planes with 8 & 10 cell AA, packs, but rated at 2200 mha or higher, and I could get 10-15 minute flights per pack. Another thing you need for electric flight is a good field battery charger. Next a Radio, and receiver. Do you see the cost starting to add up? Yes, I know you're young and it's hard to get money together for this type of hobby. I was young once, and I sold fishing worms for 3 summers straight to pay for my 1st motor bike. $400.
    Yes SPADS are cheap as far as the building materials go, but there is still the initial investment to get the proper equipment to get a proper built SPAD in the air. We are here to help you, and we would all rather hear about your success story than to hear. "I gave SPADs a try with this set up, and it didn't fly worth a &#@#$!" Well of course it didn't fly if you didn't do things the right way.
  16. #16
    coolbean's Avatar
    Join Date
    Jul 2005
    liberty, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Props are cheap. relativly... And the one you made is very heavy, has no airfiol, and how exactly is it attached to the shaft??
    It is going to work more like a fan than a propeller. Draw a whole lot of amps and make very little actual thrust.
  17. #17
    Join Date
    Jul 2003
    Carrollton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I didn't see the part about homemade prop. Forget the homemade prop. Props are cheap. Glue the homemade prop to a pencil or a stick and make one of those hand helicopters out of it. If it goes up when you twirl it, Great! You made yourself a propeller, but I wouldn't trust it on a motor spinning that thing at well over 10,000 rpm, and with a foam nose cone?? That's just nuts!
    What part of Texas are you from? If you are near Dallas why don't you come out to Denton March 24th. Attend SPADs over Texas and witness for yourself how SPADs are made and how they fly. If you enter the raffle, there is a chance of winning something SPAD related. Perhaps a SPAD kit, or well you'll just have to come see won't you?
  18. #18
    Join Date
    May 2003
    Ste-Madeleine, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: export!
    I like it post plan for it sure!!!
    what's the spec????
    dan
    Coro fly like balsa...
    But it crash so much better!!!
    aeromaskou.com/forum
    The first french SPAD Forum
  19. #19
    export!'s Avatar
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here ya go;
    http://www.smsa.pwp.blueyonder.co.uk/Bugi.htm
    I have a 1300mAh 2 cell LiPo, 15A BESC and an Esskay 400XT in it. I actually killed it this morning on a low inverted pass! Very impressive crash. I could repair it but I want to build another one at 150% scale. I think that puts the wingspan at 39" if I remember.
    Scott
  20. #20
    Join Date
    Jul 2003
    Carrollton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the Bugi plans! You should post them in a new Topic by name, makes it easier for others to search. Take me for example, several months from now I'll be looking for them, and be like ok where did I see those plans for that cool Bugi plane???
  21. #21
    kbear's Avatar
    Join Date
    Sep 2004
    Denton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    export, what your all up weight on the one that died.
  22. #22
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: FantzyPantz
    Use the link and right clink save as on your PC
    I do it everytimes there's something interesting!!!!
    Right now i'm cleaning 1500 airplane plan that I have download!!!
    Dan
  23. #23
    export!'s Avatar
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: kbear
    370 grams
    It was a sweet flyer at that weight (as you can imagine).
  24. #24
    Join Date
    Nov 2003
    muskegon, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DUDE--------------DON"T USE THAT PROP!!!! I shudder to think of things that could happen if you make just the smallest of errors...
    I certainly admire your ingenuity.........but that prop, and 10,000RPM, is a certain recipe for disaster!!
    GWS makes a great number of electric props that will suit your needs, and they won't amputate your fingers!!
    [X(]
    RC MANIAC-PRO BRO 1900-AMA# 95841
  25. #25
    export!'s Avatar
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    bump
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
