Can anyone find....
Can anyone find....
I cant find 1/4x1/4 square tube aluminum anywhere
Its used on the KOMBAT 40 Armadillo fuse with a hard wood center the wood works real well to stiffin
Checked ACE, LOwes , homecheapo, everywhere no luck.
Can anyone find....
1/4" is awfully small, but, here is the only stuff i've found in the last 20 minutes of seaching.
http://www2.towerhobbies.com/cgi-bin...?&I=LXS004&P=7
TUBE
I though so to but I have hit 3 ACE stores and Im always looking never see it, I think the inside diameter is 1/4x1/4 same stuff the
KOMBAT 40 uses
KOMBAT 40 uses
NB, CANADA
Can anyone find....
If you read the Tower description, you will see "Easy to bend and form." Not the best for a fuse - wonder if it is the relatively soft pure aluminum or the more rigid aluminum alloys preferred for this sort of application.
Ross
Ross
Can anyone find....
here is a site for alum bar, just about any size and shape.
http://www.onlinemetals.com/merchant...owunits=inches
