Spad Plans for free
Spad Plans for free
Just incase you don't already know Us SPADders love to share everything. Here is the list of airplane plans you can easily download from the SPADworld.com web site.
BUHOR
Ciggy Pack SPAD
Coro - Later
CoroCAP
CoroSpit
CoroStang
CoroStar 40
CoroWonder
Dagger
Dart
Das Plas Stick
DDust
Debonair
Debut
Defender
Demon
Derelict
Derringer
Dogfighter
Dogno
Dominator
Dynamo
Flat Bat
Friday Night Special
GeeWizBee
GPS Scale: Zero & Spitfire
H. on Rails
Kaos
Magic
Mig 7
Mini Dinoii
Mini Das Plas Stick
Panic
Pizza Box Flyer
Protwister
QHOR
Sassy's Rudder Rail
Saturday Night Midget
Saturday Night Special
SPA3D
SPAD Stick
Spad Trainer
Spadet LC-40
Spadrastic
SPADStang
Spazzler
Stik
Ultra Spad Stick
With more to come!
__________________
BUHOR
Ciggy Pack SPAD
Coro - Later
CoroCAP
CoroSpit
CoroStang
CoroStar 40
CoroWonder
Dagger
Dart
Das Plas Stick
DDust
Debonair
Debut
Defender
Demon
Derelict
Derringer
Dogfighter
Dogno
Dominator
Dynamo
Flat Bat
GeeWizBee
H. on Rails
Kaos
Magic
Mig 7
Mini Dinoii
Mini Das Plas Stick
Panic
Pizza Box Flyer
Protwister
QHOR
Sassy's Rudder Rail
SPA3D
SPAD Stick
Spad Trainer
Spadet LC-40
Spadrastic
SPADStang
Spazzler
Stik
Ultra Spad Stick
With more to come!
__________________
Spad Plans for free
This link causes a recursive frameset error. Please fix this. I has been happening for quite some time. You might get more visitors if your site worked right.
Spad Plans for free
Works okay for me. You might want to confirm this is an error others are having as well besides yourself, before making these kinds of remarks. Even, then, there's no need to be snide. Snideness is rampant on discussion forums, unfortuneatly. I think it keeps a lot of potential posters at bay, for fear of being snipped at at the first opportunity. IMHO.
Spad Plans for free
Upgrade from IE 3.0 and it won't do that.
Well said Frank. Being a member of 10 forums and Moderator on 2, Snideness people do run rampant. Moderating such people id easier said than done. On another board we just keep track of snide remarks being found on a secret score board that only moderators can see. After 3 they get warned after 10 they get warned again. After 15 they get their IP banned for a week and after 20 their e-mail IP and user ID are all banned. Make for some small member lists but they aren't helping us any anyway.
So please keep the attitude down. MAybe if it was worded like "Your site gave me a Frameset error. Can you fix this?" This would have been a PERFECT to the point post and would have gotten immediate results such as a Linear format Link that would take you straight to the plans.
Spad Plans for free
I have IE 6.0. Every time I go to this link, the top frame has a recursive frameset error. I was NOT being snide. I thought I was trying to help. Too many times we are PERCIEVED as being snide. I should have worded it better. Others around me are getting this also.
Spad Plans for free
Here is the link getting the error. It only occurs if your resolution is greater than 800x600. The bottom frame is set to have a height of 598 pixels. If your resolution is 600 pixels or less in the vertical, then you will never see this top frame. I run at 1600x1200, and everyone around me runs at least 1024x768, so they will se it also. I am just trying to help. I do this for a living at a very senior level.
http://www.spadworld.com/supplies_su...edFrame-24.htm
If you do a view source from the top level menu in IE, then you can see that the page consists of a frameset of 2 source frames. The above link is the source for the top frame, and is the one getting the error.
Spad Plans for free
Well thank you. I'll just do this until I can get rid of the frames. I don't like them anyway I just liked my buttons. I'm in the process of changing the layout of the site anyway.
IF YOU NEED ONLY PLANS AND GET AN ERROR CLICK HERE
This should stop the frameset error.
Only thing I know though is do you have a firewall? If so and you have Referal URL turned OFF then it won't load. This is to deter outside linking and framing my site within another. I had a huge problem with an individual framing my site with his URL.
u channel fuselage
can someone tell me where in what section of home depot I can find the U channel fuselage? I have looked and even asked but have not been able to find it. probably because I'm not sure what it is used for besides making airplanes...
I am going to build one of these planes...
thanks
Bugs.
thanks
Bugs.
Spad Plans for free
It's used alot for framing and bathroom installations, like for showers and such. I find it in the same area where the screws, bolts, rope and chain are located. It's usually located right next to long threaded rods and such.
