S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
.15 ,DAZI 36" wing
Old 05-01-2009, 08:29 AM
emeraude
Default .15 ,DAZI 36" wing
Hi , jut finished making my glow powered flying wing its a scaled down dazi with a .15 asp glow engine.AUW without servos is 560 gm , shall i go for standard servos or micro ones .The wing span is 36", what is th etarget weight for a .15 powered glow model, i know there are a lot of variables involved just wana know the generic value.
ID:	1190049   Click image for larger version
ID:	1190050   Click image for larger version
Old 05-01-2009, 02:58 PM
Team_Monkey
Team_Monkey's Avatar
Default RE: .15 ,DAZI 36" wing
You are just over a pound, that's great! You could probab'y get by with some strong 10g servos if you prop it with an 8x3. Or use something like an HS-81 or HS-85 if you plan on more speed. No need for standard servos on that.
Good luck!
Old 05-07-2009, 01:33 AM
emeraude
I made the mistake of mounting the engine infront of the nose instead of within the nose, this made the wing nose heavy .Had to install standard servos in the backend of the centre section and rx and flight batt b/w the fuel tank and the servos.Also installed one 9 gm servo for throttle and one 18 gm servo for nose steering.AUW Dry is 810 gm.Still a shade heavier in the nose.I alos put some lead behind the verticl fins on both sides to balance.The flight performance was fast , with a little sink on hand aunch.ROG is not possible it runs and runs but does not lift.Probably due to the position of the main landing gear far back from the cg mark.I am thinking of removing the steering mechanism and install a fix landing gear.Here are some flight pics
ID:	1193652   Click image for larger version
ID:	1193653   Click image for larger version
ID:	1193654   Click image for larger version
ID:	1193655   Click image for larger version
ID:	1193656   Click image for larger version
ID:	1193657   Click image for larger version
ID:	1193658   Click image for larger version
