What is this
TX
What is this
My friends dad gave me a huge spad when they moved a few years back... he has flown it and it flew well but the ryobi engine he had oon it no longer runs... I dont know where this plane came from what it is or what engine I need to put on it? Unfortunaely all this plane has done is sit in my parents barn for the last 2 years and I wanna get it goin again! any help will be appreciated!
CA
RE: What is this
that realy doesnt look like a standard spad from a plan. it looks like its somebodys own design. it looks cool and I bet it has some history to it. try to find what size engine is on it and replace it with a simular engine. there are plenty of imported 2 stroks now, Just get one that is about the same CC.
my hunch is that the ryobi is a 33cc
its a neat plane, take care of it!
TX
RE: What is this
I dont know the engine he had on it.. he had tken it off and only left the mount and it bolyed up to my old ryobi weedeater engine but I dont know the size... what i think is wierd is hat the plane says zenoa on the sign so that couldve been the kind of engine he had on it?
TX
RE: What is this
Its the pvc fence post yes... even without the egine on it its extremly heavy its gotta atleast be over 15 pounds with the lil ryobi i have bolted up on it...
IL
RE: What is this
Looks like the USS with the 4" PVC fence post with the Ryobi 31 CC engine. Here's mine I made. Looks very similar.
Flys like a trainer. I have added a smoke system to this setup. Uses a windshield washer pump to force a mixture of automatic transmission fluid-diesel to the muffler. pump is controlled by a micro-switch. Smoke is awesome looking in air !!!
http://spadworld.net/gallery/displayimage.php?pos=-234
TX
RE: What is this
theyre very similar! except for the fact yours is a low wing! um the 31 cc ryobi what modifications did you put on it to make it lighter?
IL
RE: What is this
Cut off anything that doesn't relate to flying. Do a search on "Teaching a weedwacker to fly". They give a step by step approach on converting a Ryobi 31 engine from weedwacker to flight.
RE: What is this
You ought to be able to fix the engine easily enough.
If you don't want to fix it yourself, you can take it to a small engine repair shop, and pay for them to fix it.
They likely have a pile of used engines out back and the repair cost would be reasonable.
maybe even get a newer used engine worst case.
it probably needs the carb cleaned and rebuilt if the rubber parts have deteriorated.
