Really stupid question about coro...
Well, I'll probably be the laughing stock of the entire forum now, but what the heck... The only stupid questions are those you never ask, right?
Ok, here goes... Is it possible to roll up coro sheets? I know how dumb that sounds, but I'll be goofing around in a hot city all day with that roll on my back, so I was a little worried about warping and such And dragging a 4 x 8 foot coro sheet around can be somewhat... unmanageable
Ok, now you can laugh
Don't think so. It will crease and bend and be unusable. I can get 4 X 8 sheets in the back of my 4 X 6 pickup box, but I curve it up around my back window so I can close the tailgate. It's a gentle curve. The stuff is just to stiff to roll.
TX
Piraro76,
Not a stupid question. Coro won't roll and maintain the properties you want. I would suggest figuring out what size sheets you need (with the flutes in the correct direction) and cut the 4'x8' sheet into those dimensions.
A good suggestion is in the SPAD Debonair plans HERE.
It would be easier to haul a few 2'x4' sheets around (and tell everyone it's your "new airplane!") than the full 4'x8' sheet.
Blue skies,
DL
BTW, a stupid question is like when the woman went to her doctor for an exam, and the doctor looked at her and says: "Well, from the test results, it looks like you're pregnant!" The woman looks back at the doctor and says: "Are you sure it's mine???"
Blue skies,
DL
NE
Do bring a knife... but if you have to carry it arround for long... don't cut it all the way through!
Figure out what sizes you want and what cuts to make and then basicly cut hinges at the dimensions... then you can fan-fold it and carry it in one piece without them sliding on each other, and being so hard to handle.
(jut my $.02)
(jut my $.02)
If it's OK to ask stupid questions...is it really OK if the ali rail can twist by about 20 degrees. Nearly finished my SPA3D with an Irvine 46.
Anybody add anything to prevent the rail twisting ?
One other question. On the 5/32" music wire...Wouldn't it be better to use a 4mm carbon rod than a flexible wire ?
If wire does the job wire it is. Did send the little woman off to the music shop today with exact instructions but she came back with 1/32" music wire.
