24" wing span and pqhor
IL
would it be at all possible to make a 24" wing span pqhor powered by a norvel 25 bushing. the reason i ask is i have 2 sheetss 24 x 24 and i know i can make a pbf but i wanted to see if it would work as a hor
NY
I love the PQHOR videos. Did you modify any of the dimensions from the original design i.e. fuselage length control surface dimensions etc? I have 24 x 24 coro I want to put to good use in the air. You appear to have had success with your version and I would like to make a similar model.
