S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
YIKES!!! Crashed by DPS today
Reply
Old 07-27-2010, 05:58 PM
wjbender
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default YIKES!!! Crashed by DPS today
I built a DPS as a combat plane with a Thundertiger pro 46. I was a rocket ship and performed beautifully. On my second pass arount the field today I had no ron control and she went down. I found the gears in the ron servo (Hitec HS635HB) stripped. All I can figure is that flutter must have done me in.
Do you guys usually use metal gear servos?
any suggestions to prevent this from happening again?
wjbender is offline
Old 07-27-2010, 06:30 PM
mdavies31
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: YIKES!!! Crashed by DPS today
Did you taper the ailerons near the wingtips?
mdavies31 is offline
Old 07-27-2010, 07:10 PM
Clean
Clean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got standard servos in my wing, but I do have two of them and I have wingtips on mine to get that vortex away from the ailerons. I also have a TT 46 on mine and it does go like stink, even with only an 11x5 on it.
Clean is offline
Old 07-27-2010, 09:42 PM
wjbender
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NO I will do that on the rebuild
Is a non metal gearservo OK?
wjbender is offline
Old 07-27-2010, 10:16 PM
mdavies31
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All I have ever used are standard ball bearing servos. Futaba 3004's and Hitec HS425's.
I have built seven DPS's, three 40 sized, two 60 sized, one with a Roybi 31 gasser and a 40 size twin.
I learned about tapering the ailerons on the SPAD site and have never had a problem with flutter.
Old 07-28-2010, 06:09 AM
Clean
Clean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't even use the BB servos.
Clean is offline
