A Few Questions????
A few questions on you airplanes.
1. Do you guys mess with airfoils, What is a common one for a gold airplane.
2. I see I think two different hot areas of racing one in Sacramento area and one so. cal and arizona area. Are the rules basically the same?
3. Are all composit airplanes legal I.E. molded wing, tail and fuse?
4. What is a good YS motor to build for. { I guess I should ask Richard V. this I used to do the F-1 thing with him a hundred years ago}
5. Is there an approval committe for airplane designs?
Thanks for your time
D.E.
Hey Guys,
A few questions on your airplanes.
1. Do you guys mess with airfoils, What is a common one for a gold airplane. Some do, some don't. As a general rule, the faster you want to go, the more you will need to maximize the performance of your airframe. In the faster classes, this frequently means substituting or modifying the airfoil. Although I've designed and built a wing for a winning Gold Class racer, I'm a Silver racer, so it's likely better to let the guys that routinely race in Gold advise you of a specific airfoil.
2. I see I think two different hot areas of racing one in Sacramento area and one so. cal and arizona area. Are the rules basically the same? There are many similarities, but also substantial differences. Your best bet is to consult the rules for each major venue with which you wish to compete. The rules for So-Cal/Arizona are here: http://www.rcpro.org/html/rules/warb...ird_racing.htm The rules for the SAM Warbird Series are available here: You can compete and have fun in both, but being a top-level competitor will likely mean maximizing your design's performance for one vs. the other, or having multiple airframes. To better answer your question, I can tell you that the major similarities are:
