If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    pjakew's Avatar
    Join Date
    Jul 2008
    Willits, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    8th Scale TA-152 Assembly Videos
    Hey Folks:
    Tim and I are doing some video segments on construction of his laser cut TA-152 kits. Even though this will focus on the Focke Wulf interceptor, this technique can be used on just about all of 8th Scale Warbird wings. Here is the first video I assembled. I should have part 2 done in a couple of days. This is an ongoing series, but at least it gets those who want to build one of these kits a little bit of help and instruction. Enjoy.
    http://m.youtube.com/watch?v=DkZYIcFkOSs
    \"You Can Teach...Monkeys To Fly Better Than That!\"
  2. #2
    pjakew's Avatar
    Join Date
    Jul 2008
    Willits, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 8th Scale TA-152 Assembly Videos
    Part 2 done. Tim is going to work on the other wing section, and then we will complete the video. May be a little down the road.
    Enjoy the videos and give some feedback.
    http://m.youtube.com/watch?v=rvfaXFqV6JQ
  3. #3
    Iron Dog's Avatar
    Join Date
    Feb 2009
    Sacramento, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jake and Tim,
    I love picking up little tips and tricks from other builders. Even though most of my wings are jig-built now, some little nuggets I found helpful:
    When CA-ing the sheeting, I always found it too tricky to try to apply pressure relatively evenly across the entire surface waiting for it set without accelerator. If I sprayed an area with accelerator, then the glue would often
    set in a nearby area (due to overspay) before contact was made. Eventually, I gave up on CA-ing much of my wing sheeting, and just used aliphatic wood glueand pin the sheeting to the ribs; but, then get bothered by all the pin holes I'd have to fill and sand. Spraying the back of the balsa sheet with accelerator so that the glue would set nearly instantly in one area that made immediate contact, but not in others until ready, seems to be a tip worth trying.
    Thanks for taking the time to do these videos. I look forward to the next installment.
    WARNING: High-nitro fumes cause an unusual form of mental debilitation resulting in excess expenditures on racing airplanes.
    P-39 Airacobra Brotherhood #17
  4. #4
    pjakew's Avatar
    Join Date
    Jul 2008
    Willits, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    3 more videos, still have one more to do to complete the wing series. Check them all out. Here is the link to the 3rd video.
    http://www.youtube.com/watch?v=F2Yiq...&feature=g-upl
  5. #5
    Join Date
    Feb 2010
    Hemet, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why not build sheeted foam wings with spar? They are lighter, much easier and more accurate.
    Good work and fun to watch though, keep going!
    DE
  6. #6
    tdstaf's Avatar
    Join Date
    Apr 2005
    sacramento, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: D.E.
    DE
    D.E, Thanks for your input.
    I have done them both ways and to make a foam wing accurate it would have to have three panels cut in order to have the airfoil consistant. When they are built that way I have found they are not any lighter or stronger it it takes longer to lay up and I have to wait for it to dry. I'm Impatient!
    When I'm by myself building I can have one of the halves completed with alierons, leading edge, and tip In about an hour and a half so this tends to be my prefered method of assembly. It's just personal preference, I like built up wings.
    Who says scale warbirds have to be GIANT.
  7. #7
    pjakew's Avatar
    Join Date
    Jul 2008
    Willits, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just to let everyone know, the final video to complete the wing series that Tim did is done and posted. Just look at the previous links to get to my Youtube page and you can find it. I sure had a great time doing the videos and I learned a ton. It should make my next project a lot easier.
  8. #8
    vertical grimmace's Avatar
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did you guys ever race this thing? I am wondering how it does?
    Let's just say, they will be satisfied with less. " Ming the Merciless
    BUSA Bro # 13
  9. #9
    tdstaf's Avatar
    Join Date
    Apr 2005
    sacramento, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It Hasn't been completed yet. Schedules haven't worked as of late to make the fuse video so I'm going to just continue to build it on the other thread it has been on to complete it for march racing.
    Tim
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
