Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing > Scale Racing
Reload this Page >
Team Iron Dog Air Racing build for upcoming season
Scale Racing Discuss all aspects of semi-scale pylon racing.
Old 12-31-2017, 11:19 PM
Iron Dog
Iron Dog's Avatar
As this is the first panel of the laser-cut wings to be built, I feel the need to test the fit of the wing to the wing saddle.
Perfect fit -- you did great, Steve! Thanks!
ID:	2249549   Click image for larger version
Old 12-31-2017, 11:27 PM
Iron Dog
Iron Dog's Avatar
Bottom sheeting completed. I sliced along the laser-cut perforations at the trailing edge of the ribs to cut the split flap free. Flap and aileron hatches installed.
ID:	2249551   Click image for larger version
Old 12-31-2017, 11:39 PM
Iron Dog
Iron Dog's Avatar
Second panel underway. I found it much easier to cut out the half-rib portions of the split flap before sheeting both sides, this time. I cut them loose, then tack-glued them with just enough medium CA to hold them in place while sheeting.
ID:	2249553   Click image for larger version
ID:	2249554   Click image for larger version
ID:	2249555   Click image for larger version
Old 12-31-2017, 11:43 PM
Iron Dog
Iron Dog's Avatar
Finishing the basic structure of the split flap:
ID:	2249557   Click image for larger version
ID:	2249558   Click image for larger version
Old 01-01-2018, 12:05 AM
Iron Dog
Iron Dog's Avatar
Dihedral brace installed and wing panels test-fit together. Fuse set on top to double-check fit to wing saddle prior to the first prototype wing joined. Again, I am very happy with the fit.
Visible in the background of the first two pictures is the original design of my wing. The original design was hand-cut using formica templates; and the wingspan was extended 4" beyond true scale. This new CAD-designed wing is true to scale. Yes, you heard right, TommyGun . . . aside from a 1" extension in the tail moment (to compensate for the weight an engine mounted in the nose, rather than mid-fuselage mounting in the full scale plane), this new wing design means this plane is exact 1/8th scale!
ID:	2249560   Click image for larger version
ID:	2249561   Click image for larger version
Old 01-01-2018, 12:13 AM
  #31
Iron Dog
Iron Dog's Avatar
Found it necessary to reinforce the structural rigidity of the flap with 1/32" ply glued to the inside.
ID:	2249563   Click image for larger version
Old 01-01-2018, 12:32 AM
  #32
Iron Dog
Iron Dog's Avatar
Second wing started:
During the build of this wing, I detailed better shots of the modifications to the wing for installing fixed gear block, rather than retracts the wing was designed for. I used the cut-out for the rear retract mounting block, and extended it forward to compensate for the additional width of the single fixed gear block:
(Pic 1) Block put in place against rear retract rail cut-out;
(Pic 2) Razor saw used for depth-cutting the additional width from the ribs, at angle;
(Pic 3) Cut-off wheel used to extend the width to the depth cut
(Pic 4) Final picture shows me sanding the necessary angle in the ribs at the original rear cut out.
ID:	2249565   Click image for larger version
ID:	2249566   Click image for larger version
ID:	2249567   Click image for larger version
Old 01-01-2018, 12:40 AM
  #33
Iron Dog
Iron Dog's Avatar
Four wing panels largely built now. Marking where to drill holes for Robert Hinge-point hinges for split flaps.
ID:	2249569   Click image for larger version
ID:	2249570   Click image for larger version
ID:	2249571   Click image for larger version
Old 01-01-2018, 12:46 AM
  #34
Iron Dog
Iron Dog's Avatar
Success -- they work! Not bad for my first time designing and building split flaps.
ID:	2249573   Click image for larger version
ID:	2249574   Click image for larger version
Old 01-01-2018, 12:55 AM
  #35
Iron Dog
Iron Dog's Avatar
Wing halves joined.
Wing tip blocks glued on, and carved/sanded to shape.
ID:	2249576   Click image for larger version
ID:	2249577   Click image for larger version
Old 01-13-2018, 11:38 AM
  #36
tdstaf
tdstaf's Avatar
Looking Good you two..
