Lancair Legacy
Lancair Legacy
Hi guys, does anyone know if there are any kits or plans available for the Lancair Legacy 2 seater with retracts... Iam looking for 1/4 or 1/3 scale ideally, is there anything out there???
Cheers- Marty
Cheers- Marty
RE: Lancair Legacy
Hi Kevin, I think its likely to be the Great Planes Lancair ES (see below) on Ebay if the one you are refering to is an ARF and is 60 sized.... they do look similar but the Legacy has a different canopy profile, retracts and has a different wing design. That said it would be possible to kit bash the ES into a Legacy but I was ideally looking to see if I could find a Legacy kit in 1/4 or 1/3 scale, such as used in experimental giant scale class R/C pylon racing...
CA
RE: Lancair Legacy
Kevin's not seeing things. I also saw the ad on Ebay and it is a Lancair Legacy ARF. But, its 40 size with 61" wing and no retracts. Definitely not the GP Lancair ES.
RE: Lancair Legacy
ORIGINAL: stregaracer007
CA
RE: Lancair Legacy
Just checked eBay and its gone.
The company that posted the ad was called SkyDesignUSA. The ad said they were the US distributor and located in Pennsylvania. When I did a search of their other items on eBay, I saw they also offer several other kits: Quickie (homebuilt), Long-EZ and Cessna 182. All ARFs.
From the pictures, the kit comes painted (blue and white) and included a full set of hardware. The only bad thing I saw was the cowl color did not match the fuse. The cowl looked off-white; whereas, the fuse was bright white. That and the absence of retracts. Also, it doesn't have the Legacy wing design, so it looks more like a Lancair 320/360.
Just did a search and found the kit on eBay Germany(?):
http://stores.ebay.at/hobbyshoppingm...erLinksQQtZkm?
RE: Lancair Legacy
Never heard of 'SkyDesign' and nothing came up when I did Google web search that I could find.... the link to German Ebay showing the ARF Lancair looks interesting just would now like to see the SkyDesign website (if it exists) for some specs and info on their kits,
I would really like a Long-Eze also if I could find one???
CA
RE: Lancair Legacy
Well I found their website, but its still under construction.
http://www.skydesignusa.com/
Updated: I found out whose making them: www.avia-richmodel.com
My Feedback: (45)
RE: Lancair Legacy
All of the RichModel aircraft that are in the US now, the LongEZ, Quickie, electric and .40 size, HellCat (beautiful airplane), Electric Extra330, LancAir (another beautiful airplane) are all available now through Fulton's Hobby shop in Wheeling, WV 304-233-5355. or at www.fultonshobbies.com The website will be updated very soon. Also, I'm currently working on rewriting some of the instruction manuals,
Arch Stafford
Arch Stafford
RE: Lancair Legacy
Cool, I like the look of their LongEZ does anyone have some more detailed pics of the LongEZ as its a bit hard to tell overall quality from the posted pics...
Cheers-
Cheers-
My Feedback: (45)
RE: Lancair Legacy
The Long EZ is really pretty and excellent workmanship. Another guy built one and his post is here. Do a search on Rich Model and you'll find it. He goes into some detail and he even added a nose gear retract for scale appearance. I can take pics if you'd like of mine, or even just of one in the box if you want to see,
Arch Stafford
[email protected]
Arch Stafford
[email protected]
RE: Lancair Legacy
DC
RE: Lancair Legacy
The Lancair used in Giant Scale is not the Legacy...The Legacy is a little different..The full size Legacy holds the World record at about 347 mph..Owned by Rick Schrameck, it was the first one built from the factory kit...Took about 4 months...It's supercharged and was flown by Dave Morss...
usrainfo.org has Giant Scale Lancair race plane kits available, pricey.....
They run about 220 mph with an Aerrow 200 for power and hold the record in the experimental class...No longer raced, there might be a few left...Post an inquiry in the website....
CA
RE: Lancair Legacy
Hate to burst your bubble, but the world record was broken last year by the Thunder Mustang.
June 23, 2005
Blue Thunder Air Racing is proud to announce that on Saturday June 4th, John Parker piloting Blue Thunder, set two new world speed records during the EAA Golden West Regional Fly-In and Air Show in Marysville, CA. The Class C1c 3km world record was upped 30mph to 374mph. In the same class, the 15/25km world record was upped 75mph to 376mph.
Blue Thunder’s fastest pass was an astonishing 383mph, making Blue Thunder without a doubt, the world fastest normally aspirated aircraft.
If it makes you feel any better, Darryl Greenamayer flying a Lancair Legacy won Gold for the fourth time in a row at 364.9 mph.
June 23, 2005
RE: Lancair Legacy
Hi Marty,
Wendell Hostetler offers plans for a built-up version of a Lancair 4 in a giant scale. Wendell can make the plans most any scale you would like. You maybe be able to modify it to make it a Legacy without too much trouble.
I hope this helps
Carlos G
I hope this helps
Carlos G
RE: Lancair Legacy
Hello out there
I need a little help with a friends Lancair- Legacy 40 size, He got the plane to me and the CG was off bad, the book says its 68mm from the leading edge, I first took the steel rods out of the tail and replaced them with carbon fiber, BUT am going to have to put almost 1 Lb. of weights in the noise to get the CG right, I have moved ever thing I can to the nose and stll going to have to put some 14 oz in the noise, Is the CG right in the book, do I check the CG right side up are turn the plane upside down??????
Would love the HELP
Keep it in the air
Thanks Wildman
Would love the HELP
Keep it in the air
Thanks Wildman
WA
RE: Lancair Legacy
I too have this same plane and problem as poster above, Is the cg of 68mm not correct? Plane balances upside down at 3.35 inches and would require about 14 oz weight at 68mm. D not want to fly until I know for sure. Any info would be appreciated.
PA
RE: Lancair Legacy
Hello Arch, I called the hobby shop you mentioned and they no longer carry rich models. Question: Did you have or build a Lancair-Legacy? I just finished and find the plane will need about a pound of lead in the nose to get the CG. Not good!
Thanks, CTKeller
Thanks, CTKeller
PA
RE: Lancair Legacy
I just finished my Lancair and find that it is really tail heavy. It would take a pound of lead to get the right CG. The guys at the club last night suggested moving the engine forward. I check out putting in a OS 91 4s and it would have to be about 6" ahead of the existing fire wall!!!!!!
I think that this model plane is a copy of the actual plane but they did not do the math to know what the weight distribution needed to be. I'm afraid it will be a hanger queen.
