DOminator 1500
DOminator 1500
What kind of participation in this class is being experienced? Are there enough competitors to make this a worth while investment?
If so, what is the prefered engine, the Tigre or the Moki. Also, what are typical top speeds with this airframe?
CA
RE: DOminator 1500
They will be racing at Parker Arizona this month.
http://www.usrainfo.org/2006Blue%20Waterflyer.pdf
http://www.usrainfo.org/AZentry.pdf
RE: DOminator 1500
Pilots at the usra races use the moki 2.10
the dom plane specs are in usra rule
kit is prefered but scratch building is ok built to specs
RE: DOminator 1500
My reading of the specs are basically minimum measurements at various locations plus exposed control horns.... there is nothing that specifies airfoils... pinching the fuse sides in after wing etc or many other minor mods that add up to a slicker airframe similar to what is done in 428 racing. Always wanted to build one of these for fun... or even to race if there ever was a convienent opportunity on the east coast.
RE: DOminator 1500
Then it should be put into the rules exactly what is/or is not allowed otherwise if I built a homegrown Dominator sporting a 66-012 airfoil fiberglassed/painted wing with skinned sealed hinges and showed up at a race I would expect to fly as nothing in the rules states I can't do that. It may be obvious to you and the others flying this provisional class that it is not the intent to permit these types of mods to the one-design - but unless you put the cap on the genie he will get out.... as an example Quickie 500 is a long long way from the original intent Spickler 500 and a K&B in cost, complexity amd number of pilots participating. JMO. And I still have always wanted to build one of these.
My Feedback: (51)
RE: DOminator 1500
The dominators are used to be an "entry" level class.
They intend to keep the class as common as can be. Many of these Lanier Dominator owners vaccum bag the wings so there are some changes used. Why dont you go on the usra web page and ask there?
I fly Gt class so I am not in a position to answer correctly.
No doubt the Moki is engine of choice.
RE: DOminator 1500
I have posted these questuions on several sites. The USRA contact has never responded to me. I did however receove a call from a very nice gentelman a week or so ago answering my questions.
The plane looks like a lot of fun.
Apparently the Moki is the engine of choice.
Apparently the Moki is hard to find at the moment.
The speeds are in the 120 to 130 mph area.
Participation is very limited.
My take is if you want to build it for fun then do so. If you want to race then be willing to travel and don't expect to many competitors in your class.
My Feedback: (51)
RE: DOminator 1500
I have not seen the posting on the USRA web site
I would disagree that entries are low. It is a beginner class so they will always be lower than other classes.
All you need is 4 or 5 to make a heat race. Last year at Parker, az they had enough for a class
First race of the year in Rantoul, Il they had enough for a race, yes at Ohio they didnt but that is because a lot of the pilots come from the west coast and Ohio is a long drive, Depending on where you live and what races you plan to attend it could still be a good purchase. shoot at Ohio there were hardly any entries other than in GT class!!
The race next weekend at Parker, az has over 70 entries and this sport is starting to grow in huge leaps and bounds.
there will for sure be a race for them there.
